Tranny Gear Ratios (Cali People)
Old Dec 11, 2004 | 08:27 AM
b17hybrid's Avatar
Default Tranny Gear Ratios (Cali People)
Just wondering if gear ratios has anything to do with smog. Trying to ref my b17 swap, but I have an ls tranny. Last time I went to the ref, he didn't say anything about it, but could it have an affect on how emission operates. Ls = longer gear ratio. GSR = shorter gear ratio
Old Dec 11, 2004 | 10:11 AM
Reelizmpro's Avatar
Default Re: Tranny Gear Ratios (b17hybrid)
On the dyno it does make a difference in the load. On a regular HP dyno, you can get different readings depending on which which gear the operator goes upto. Some dyno upto 3rd gear and some go to 4th (usually 1:1). Tall LS gearing will put more load on the motor for a given gear at given speed. I think overall, the difference in emissions though is small unless it causes detonation.
Old Dec 11, 2004 | 10:24 AM
b17hybrid's Avatar
Default Re: Tranny Gear Ratios (Reelizmpro)
Thanks for the response. Cleared up my question.
Old Dec 11, 2004 | 05:41 PM
fourthgenhatchB17's Avatar
I REF'd my B17 with a LS tranny...no problems.
Old Dec 12, 2004 | 06:44 AM
Wes V's Avatar
Default Re: Tranny Gear Ratios (fourthgenhatchB17)
My feeling is that it DOES make a difference! However I can't verify anything with solid facts.
Here is my thinking;
When they do the smog check, they put the car on rollers and take readings at 15 mph and also 25 mph. A GSR transmission would result in higher engine RPM's then what an LS transmission would.
It could lead to a difference.
If it does really matter, then the thing to do would be to borrow as tall a tire combination as possible for the test and that would alter the over-all gearing to lower engine RPM at the given MPH speed.
As with fourthgenhatchB17, I passed the referee process with an "LS transmission" under my engine.
Wes V
CrxFihn
Apr 2, 2013 03:08 PM
patdemps
Sep 19, 2003 01:56 PM
B16b2b
17
Jul 22, 2003 10:56 AM
squirrel
Feb 19, 2003 09:12 AM
