help- short shifter question
Old Dec 10, 2004 | 10:59 PM
tegsallgood's Avatar
Default help- short shifter question
wuttup guys. aight heres the deal- the guy i bought the car from had installed a short shifter prior to me buying it and i have a few questions...
first of all i have absolutely no idea what brand of shifter it is.
without further ado, the problems:
the shifter is reallly tight, just moving it aorund in neutral is kind of difficult to a degree.
and i cant put it into gear easily. i guess what i mean is it doesnt slip into gear, its not that it grinds or anything, ts just that you have to push a tad hard to get it in, expecially going from first to second. is it my synchro's? this makes quick shifting difficult and you know what that does to your races...
my questions is this- should i uninstall and reinstall the shifter? or is there not anyway it can really be installed incorrectly-
another question i have is do you think using GM synchromesh will aid at all?
thanks in advance fellas and any help is much appreciated
Old Dec 10, 2004 | 11:35 PM
xx dc2teg xx's Avatar
Default Re: help- short shifter question (tegsallgood)
it could be that you're used to shock shifters and how "loose" they are. MOst cars I have driven with short shifters have that notchy feel to it.
Old Dec 11, 2004 | 05:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: help- short shifter question (xx dc2teg xx)
My short shifter slips into gear just fine, most of the time.
It's probably a POS shifter that doesn't have sealed bearings in the bottom, and the through-bolt is probably too tight. On shifters with sealed bearings and spacers in the bottom, you can tighten that bolt as much as you want and the movement of the shifter will not be affected. On other shifters that require you to use o-rings and parts from the stock shifter in the bottom (like B&M shifters), it is possible to overtighten the through bolt to the point where the shifter won't even move.
So just check the tightness of that bolt going through the bottom.
Or chuck that shifter and get a better one.
Old Dec 11, 2004 | 07:50 AM
Default Re: help- short shifter question (PatrickGSR94)
thanks guys- heh no im definfitly not used to stock shifters- i learned how to drive stick on this car, and i bought it with the short shifter, but a bunch of my budies have short shifters and they are always commenting on how it feels so i just figured there was something wrong. im gonna check the thrubolt today.... any answers to my gm synchromesh queston tho? thanks for the help
Old Dec 11, 2004 | 08:26 AM
aeon's Avatar
might be the bushings also, when i installed my bushings, it made things a little harder.
Old Dec 11, 2004 | 11:25 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
So just check the tightness of that bolt going through the bottom. </TD></TR></TABLE>
yup, i bet that's it. i tightened mine a little too much, and it felt really stiff. then i loosened it a little bit and it felt fine.
Old Dec 11, 2004 | 02:01 PM
Slain's Avatar
as others have said check the bolt that holds the shifter to the shift linkage. if its too tight it will seem really hard to move. i've been running the gm friction modified fluid for sometime now. going into gears is like a hot knife slicing through butter.
Old Dec 11, 2004 | 03:15 PM
toukna's Avatar
i agree with patrick, chuck the shifter and get a new one!!!
at least that's what i'm going to do
I have a b&m shifter, the first time I install it, i tighten it too tight and it was hard to shift. Then i loosen it up, it was better but the shifting is still bleh. So, when the funds come in, (in two months... damn christmas choking me of my riches), i'll be thinking of getting a neuspeed SS. B&M 50 dollar short shifter sucks! but you get what you paid for.
Old Dec 11, 2004 | 03:59 PM
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">as others have said check the bolt that holds the shifter to the shift linkage. if its too tight it will seem really hard to move. i've been running the gm friction modified fluid for sometime now. going into gears is like a hot knife slicing through butter.</TD></TR></TABLE>
great exactly what i wanted to hear- that ***** going in ASAP- gonna go jack up the car and loosen that bolt up a bit.. see how everything is- ill get back. thannks for the help guys
integraRS-T
Jun 28, 2007 02:24 PM
eternalboy
Feb 11, 2007 08:57 PM
5poonhatch
Jun 26, 2006 08:31 PM
spontaneous ep3
Nov 28, 2004 10:44 PM
2ner
Jun 13, 2003 12:39 PM
