'91 Mazda Protege GT rims OK for use on '91 Civic?
Old Dec 10, 2004 | 07:03 PM
gregv's Avatar
Default '91 Mazda Protege GT rims OK for use on '91 Civic?
hey guys
looking at a set of 4 used Yoko winter tires for my '91 Civic Si; they are 185/60/14 and mounted on '91 Mazda Protege GT steel rims. Will these rims work OK on my Civic? My suspension is lowered 0.75" but other than that everything is stock (no big brakes). From the limited specs I could find online, Civic offset is usually 40mm(?), and I am not sure but I think the Protege is 38mm.
Normally I'd just shell out for some OEM Honda rims, but hey these are winter tires...
any advice appreciated
greg v
Old Dec 10, 2004 | 07:19 PM
91civicEX's Avatar
Default Re: '91 Mazda Protege GT rims OK for use on '91 Civic? (gregv)
if its 4x100 it should work. 185/60/14 should be the right size.
Old Dec 10, 2004 | 07:39 PM
gregv's Avatar
Default Re: '91 Mazda Protege GT rims OK for use on '91 Civic? (91civicLX)
yeah, I hope so; the offset is the only part that has me thinking.
cheers
greg v
Old Dec 10, 2004 | 08:12 PM
Rednas's Avatar
should work, but there is a chance that the offset might be off and look funny.
more likely than not it should work just fine.
Old Dec 10, 2004 | 08:30 PM
davens's Avatar
I'm going to go out on a limb and say the center hole is going to be too small on the Mazda rims. If they're hubcentric, they won't fit over the Honda hubs.
Old Dec 13, 2004 | 07:59 PM
gregv's Avatar
Default Re: hey davens you're right
give the man a cigar....
yep, tried them today and the centre hole is just ever so slightly too small; better luck next time.
cheers
greg v
Old Dec 13, 2004 | 08:37 PM
khrys771's Avatar
Default Re: hey davens you're right (gregv)
there not hubcentric, not for a honda.
323, Miata, MX3, Protégé (91 - 98) 4/100 54.1 Stud 12x1.5
Honda Civic, Si, CRX, del Sol, Prelude 12x1.5 4/100 mm 56.1mm
Old Dec 13, 2004 | 08:38 PM
khrys771's Avatar
Default Re: hey davens you're right (khrys771)
never mix car manufactures.
Old Dec 13, 2004 | 08:39 PM
Ass$nyper's Avatar
Pirate General...YARRRR
ive seen a set of rotas go on a mitia to a 93 hatch at an auto cross meet and no problems
Old Dec 13, 2004 | 08:42 PM
mrspeaker's Avatar
Cant you just bore out the center with a dremel or something to fit the honda hubs?
Old Dec 13, 2004 | 08:44 PM
khrys771's Avatar
Default Re: hey davens you're right (Mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">Cant you just bore out the center with a dremel or something to fit the honda hubs?</TD></TR></TABLE>
that could be dangerous.
Old Dec 14, 2004 | 12:19 AM
davens's Avatar
As long as the offset, bolt pattern etc are the same/similar, running other marques wheels shouldn't be a problem. The cost/reliability of another manufacturer will be safer then most Chinese knockoff wheels.
So you take the wheels to a machine shop and have them bore out the hole by a few millimeters.
That's what I've done on TWO sets of Miata rims...
Getting them bored out cost me $40/set the first time and something like $58/set the second time.
I'm running the 90-93 (14", 12lbs) on my RT4wd wagon and the 94-97 (14", 11lbs) as the street wheels on my CRX.
When compared to the stock CRX rim at 14", 17 lbs...it's a noticeable improvement in acceleration/handling. And they're dirt cheap.
I've currently got my eye out for a deal on the 92-93 BBS rims...mmmm....9lbs
Old Dec 14, 2004 | 09:06 AM
gregv's Avatar
Default Re: (davens)
not sure if I'm energetic enough to dremel out some dirty steel rims... Ijust picked up a set of clean Honda 14" steelies for $75, problem solved. The super light Miata rims, though, I can definitely see as being worthwhile to do some work to get them to fit.
thanks all
greg v
jdmer4life
Apr 25, 2006 01:19 PM
hAtChXcElR8tion
Jan 12, 2005 09:44 AM
