whats the most whp you've seen on skunk2 stage 1's
just like the title i would like to know what some of you guys have seen or put down on the dyno with the skunk2 stage 1's all motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 »</TD></TR><TR><TD CLASS="quote">just like the title i would like to know what some of you guys have seen or put down on the dyno with the skunk2 stage 1's all motor.</TD></TR></TABLE>
with ctr pistons
we made 208hp and 143tq like 3 years ago......
with ctr pistons
my setup obd1 gsr
fully built head by endyn
skunk2 stage 1 cams
str cam gears
skunk2 intake manifold
hondata intake manifold gasket
64mm throttle body
type r aem cold air intake
rc440 injectors
golden eagle fuel rail
walbro 190 fuel pump
b&m fuel regulator
wisco pistons
eagle rods
megan 4-1 headers
2/1 exhaust all the way back to an n1
new ground kit
chiped p28 with hondata s200
the comp. is around 11.7.1
(with a **** *** ls tranny)
it's untuned im hoping to get for 200 whp but i mite be a little short . im take it to the dyno on the 14th. of this month it pulls strong and run realy good to be untuned. i ran a hatch with a b16 swap and it was boosted at 6 or 7 pounds i stayed door to door with him not bad i guess? what do you'll think
skunk2 stage 1 cams
str cam gears
64mm throttle body
rc440 injectors
b&m fuel regulator
wisco pistons
eagle rods
megan 4-1 headers
new ground kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 »</TD></TR><TR><TD CLASS="quote">my setup obd1 gsr
skunk2 stage 1 cams
str cam gears
64mm throttle body
rc440 injectors
b&m fuel regulator
wisco pistons
eagle rods
megan 4-1 headers
new ground kit
</TD></TR></TABLE>nice setup, how do you like the work form larry at endyn?
skunk2 stage 1 cams
str cam gears
64mm throttle body
rc440 injectors
b&m fuel regulator
wisco pistons
eagle rods
megan 4-1 headers
new ground kit
i was gonna get these cams as well, if anyone can post any more numbers with setups i would greatly appreciate it-preferably on a b16, icey-get rid of that ls tranny and you will have a really fun car to drive.
a friend of mine put down 213 whp wit these in his b20 vtec-. couldve got more with better tuning and higher compression. his compression is about 11.5:1. he had it tuned down to 203 for daily driving tho. hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 »</TD></TR><TR><TD CLASS="quote">will im back from the dyno i made 196.3whp and 138.1tq on 93 oct. He told me it would make 200whp on race gas. I just ran out of time and money. </TD></TR></TABLE> will i hit 199.3 whp and 138.1tq but but it was like a spike. (stock bore)
What motor are you dropping these cams in? And what are you using for tunning?
The reason I asked was because I just Bought those same cams and a HondataS200 for my B20Vtec. Cant wait to have them installed!!!
the cams are in a gsr and tuned with hondata s200.
i like them alot but im thinking of trying the bc3 not sure yet but im goting back to get it tuned on 100- 125 shot of nitrous.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 »</TD></TR><TR><TD CLASS="quote">.
Ive read here on the boards that BC3's make 3-4 hp more than skunks. But dont quote me on that.
</TD></TR></TABLE>Ive read here on the boards that BC3's make 3-4 hp more than skunks. But dont quote me on that.
