PROP VALVE...40/40?
Old Dec 10, 2004 | 02:47 PM
B18C5 EH's Avatar
Default PROP VALVE...40/40?
what do the numbers mean, %, psi, I should know this by now
Chris
Old Dec 11, 2004 | 06:33 AM
B18C5 EH's Avatar
Default Re: PROP VALVE...40/40? (ITR 1007)
anyone?
Old Dec 11, 2004 | 07:32 AM
Wes V's Avatar
Default Re: PROP VALVE...40/40? (B18C5 EH)
NOBODY knows!
I've asked all over the place and other than some engineer in Japan, the information just isn't out there!!!!!
It's not a ratio, or the 30/30 valve would be the same thing.
Wes
Old Dec 11, 2004 | 10:45 AM
B18C5 EH's Avatar
Default Re: PROP VALVE...40/40? (Wes V)
Maybe it is psi then.... since the rear disks are smaller (if drums, takes more pressure to work) that might be the answer. All I know is that with my stock prop valve my rear itr disks lock before my front itr disks. I'm thinking about getting a 99/00 civic si prop valve...I wonder if that will do the trick...
anyone have anymore input?
Chris
Old Dec 11, 2004 | 02:05 PM
atcrx's Avatar
Its usually the brake bias between front to rear. Like 70/30 is 70 percent of the braking is done by the front & 30 is done by the rear.
.Grimace
Suspension & Brakes
Aug 22, 2018 08:40 AM
96accordsir
Sep 23, 2010 04:39 AM
D50boy
Jan 27, 2009 04:40 PM
who00knows
18
Mar 3, 2003 09:26 PM
intezn
12
Feb 19, 2003 12:41 PM
