Just completed swap. Have A few questions about oil
Old Dec 10, 2004 | 02:37 PM
d15maverick's Avatar
Default Just completed swap. Have A few questions about oil
Just dropped in a sohc ZC. She's running pretty good. 2 weeks and 518 miles, and no sign of her burning any oil. Here's the questions. 1:When should I change the oil next since this engine was probably not running for a while. 2: Would the fuel injectors that came off the new motor be better than my old ones? 3: If I swap back to my short ram intake, will it make the oil get dirty faster? I just wanted to know on that last one because I figured the k&n filter doesnt clean as good as the stock filter. Any answers to my questions would be greatly apprieciated.
Old Dec 10, 2004 | 02:55 PM
Recluse03's Avatar
Default Re: Just completed swap. Have A few questions about oil (d15maverick)
for the 1st couple changes i would maybe break the time in half, just to make me feel better, even tho its probably not NEEDED. was the ZC stored with oil or without? either way i'd change after maybe 100 miles, then the next after 2000, then the regular 3000.
for the short ram, nah it wont make any significant difference. if it were one of those filters connected directly to the TB, then yeah it gets a lot warmer air in the engine, but for a short ram the air should be the same temp as a stock air box, basically.
Old Dec 10, 2004 | 02:57 PM
ls_vtec_crx's Avatar
1. change it regularly unless its a freshly built motor.
2. leave those fuel injectors.
3. No, you intake system has nothing to do with making your oil get dirty.
Old Dec 10, 2004 | 03:20 PM
Default Re: (ls_vtec_crx)
Thanks for the fast replys! Leave the fuel injectors im already using, or use the ones that came with the motor? I was confused about that second one. I think ill change the oil tomorrow then. plus i notice that when I start the car I don't have a fast idle. The ZC that Im using came out of an automatic car. could that have something to do with it? TIA.
Old Dec 10, 2004 | 04:13 PM
leave the injectors that came with the ZC....
what do you mean fast idle?
Old Dec 11, 2004 | 09:30 AM
When the car is cold in the morning, it idles at about 2000 rpm then lowers as it warms up. My engine doesn't do that.
Old Dec 13, 2004 | 10:59 AM
Default Re: (d15maverick)
The engine came out of an automatic car. I am presently using the intake manifold that came with the motor and my old fuel injectors. I dont really have any drivability problems, except for a slight jerking if i dont keep my foot on the gas pedal consistantly.
Old Dec 13, 2004 | 11:04 AM
92integra_gs's Avatar
i changed my oil again after driving at least 200 miles after the first oil change ... it hadnt ran for 6 months and then regular schedule
Old Dec 23, 2004 | 08:03 PM
Default Re: (92integra_gs)
I changed my oil at 500 miles. Looked pretty good. I just saw something here on H/T about aftermarket air intakes that they make the oil get dirty faster. Is that true?
Old Dec 23, 2004 | 08:47 PM
Vtec_TrackMan's Avatar
if you use a shitty filter then yes but any good clean filter will do
Old Dec 23, 2004 | 09:09 PM
onePOINTsix's Avatar
Default Re: (Vtec_TrackMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec_TrackMan &raquo;</TD></TR><TR><TD CLASS="quote">if you use a shitty filter then yes but any good clean filter will do</TD></TR></TABLE>i dont see how this is true, most microscopic particals are going to get brunt up in the combustion chamber anyway. on a unknown motor i like to do 500 miles then go to a normal 3000mile/3 month plan.
Old Dec 23, 2004 | 09:38 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (onePOINTsix)
I dunno, when I swapped in my B20, I changed the oil/filter at about 500 miles, and it was very black... I changed again at about another 500 miles and it was fairly clean... Same also with my tranny... But my tranny and engine sat for about a year or so, that could be it...
Blaze
Old Dec 23, 2004 | 11:13 PM
michael O's Avatar
Default Re: (Blaze45)
When I rebuilt my engine I changed the oil right after I drove it around the block. Then I think I changed it around 500 miles and then at 1xxx I changed it to synthetic. Now I changed it every 3k.
Old Dec 27, 2004 | 01:53 PM
Default Re: (michaelOlson)
Thanks guys for all your input, I just ordered my cold air intake
Doom325
Oct 21, 2008 07:18 PM
ilovemyb16a
Aug 11, 2006 12:21 AM
PINKS
Aug 9, 2006 02:19 PM
1INTEGRA
Jun 4, 2005 09:52 PM
HRDCORD
Aug 31, 2003 10:27 PM
