Taking H22 Transmission out... HELP
Old Dec 10, 2004 | 01:46 PM
mdj_ge's Avatar
Default Taking H22 Transmission out... HELP
i plan on changing the clutch/flywheel by myself... is there any special tools needed??? and what bolt size socket should i be using to take out the tranny.... thanks...
Old Dec 10, 2004 | 04:08 PM
Prolink's Avatar
Default Re: Taking H22 Transmission out... HELP (yangja)
Have you tried searching for this topic?.....
Sockets needed: 10mm, 12mm, 14mm, 17mm, 19mm and 21mm.
Old Dec 10, 2004 | 04:29 PM
@ries's Avatar
i'd like to add helms manual... oh yea maybe a clutch alignment tool. have fun.
Old Dec 10, 2004 | 04:32 PM
Prolink's Avatar
Default Re: Taking H22 Transmission out... HELP (@ries)
Hopefulley, if he bought a clutch kit... it should come with the alignment tool..... I would also change the rear main seal while the tranny is out.
Old Dec 10, 2004 | 04:33 PM
hOndafienD 04's Avatar
alldata....best thing....next to a helms of course...you also need a tranny jack so the trnas doesnt fall on your face..
Old Dec 10, 2004 | 05:10 PM
mdj_ge's Avatar
what tools do u have to use to pull the flywheel out???
Old Dec 10, 2004 | 05:24 PM
Shakes's Avatar
space cadet
flywheel holding tool, 12 point sockets, torque wrench
damn i could go on forever lol.
Old Dec 10, 2004 | 05:51 PM
@ries's Avatar
Default Re: Taking H22 Transmission out... HELP (Shakes)
who needs a torque wrench? that's what impact guns are for! lol jk
yes a torque wrench is a good sugestion.
Old Dec 10, 2004 | 06:27 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">who needs a torque wrench? that's what impact guns are for! lol jk
yes a torque wrench is a good sugestion.</TD></TR></TABLE>
Sir,
Put the impact gun on the ground and step away from the engine. thats it, nice and easy.. nice and.. STOP! *turns to partners* QUICK!!!! He's going for the flywheel!!!
Old Dec 10, 2004 | 10:48 PM
mdj_ge's Avatar
what socket do i use on the outside of the tranny... there are some bolt that seems to be 14mm but when i use a 14mm socket, it seems to stip my bolt...
Old Dec 10, 2004 | 10:49 PM
Mykizism's Avatar
what brand is the 14 mm socket u using?
Old Dec 11, 2004 | 12:32 AM
PrettyLude's Avatar
loctite
Old Dec 11, 2004 | 04:47 AM
Shakes's Avatar
space cadet
Default Re: Taking H22 Transmission out... HELP (Mykizism)
use 6 point sockets unless you need a 12 point
Old Dec 11, 2004 | 05:45 AM
mrlover's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja &raquo;</TD></TR><TR><TD CLASS="quote">i plan on changing the clutch/flywheel by myself... is there any special tools needed??? and what bolt size socket should i be using to take out the tranny.... thanks... </TD></TR></TABLE>
dont' forget you need a friend to help you out since tranny case is damn heavy.
Old Dec 11, 2004 | 07:28 AM
mgags7's Avatar
you should be ok doing it yourself.....just get the trans down and let it rest on your check, just keep the pokey bits away.....
definately use 6 point sockets unless absolutely neccesary(for some unknown reason)you have to use 12 pointers.....they strip things much easier.....
definately NO impact guns on the flywheel....and be very very sure that the torques on the crank bolts are even.....or you will have chatter like biachhh!
you will need the socket to fit the crank bolts.....thats the only really weird tool i can think of other than the aforementioned flywheel holder....which you probably dont have....but could do without.....
Old Dec 11, 2004 | 10:02 AM
SKDRCR's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
you will need the socket to fit the crank bolts.....thats the only really weird tool i can think of other than the aforementioned flywheel holder....which you probably dont have....but could do without.....</TD></TR></TABLE>
I just jammed a piece of wood between the flywheel teeth and a tranny bolt
to hold the flywheel still when removing/torquing the flywheel bolts.
Make sure when you torque down the pressure plate, that teh disc stays
directly in the center or else the shaft will not line up when you go to
bolt the tranny back on
I wouldn't attempt this w/o a Helms either
mdj_ge
Dec 7, 2004 12:49 PM
Dc_John
Apr 22, 2004 07:01 PM
Ben18C
Apr 21, 2004 03:06 PM
Jonathan_ED3
Dec 20, 2002 02:58 PM
RacerMike
Jul 17, 2002 11:14 AM
