where do your guys temp. needles sit on stock gsr's?
I just replaced the thermostat w/ a new stock one and my needle hangs out just shy of 1/2 way. i'm use to it hanging out just above the "C". like 2 dashes above it because my thermostat was stuck open. just making sure this is normal. I've bled the system and there is no air in it. oh, when do the fans suppose to come on? my car is close to the 1/2 way point but the fans still don't come on? normal?
thanx!!
thanx!!
stock thermostat i think opens at 190 degrees so it shouldnt even hit half way. If it goes past halfway then you might have a problem with the fans or air in the system.
yeah.. i just got rid of my mugen thermo & put stock back in. needle sits at the line right before the middle.. about 180
CW-ITR-329
Jul 13, 2002 05:05 AM
