windshield wiper problem... never seen anything like it before
Old Dec 10, 2004 | 11:35 AM
riceisnicenv's Avatar
Default windshield wiper problem... never seen anything like it before
my windshield wipers have sparatic ranges of motion. sometimes, the windshield wipers start very close to the bottom of the windshield and sometimes they start 3 inches further up. also, at the other extreme of motion, the wiper hits the edge of the windshield sometimes and other times it stops exactly where it should. i don't know why it is so random. i experimented today and found that when i'm at idle, the wipers work like stock but anything above idle, the wipers go haywire. is this some sort of relay problem or transformer problem? help me!!!
Old Dec 10, 2004 | 01:30 PM
Default Re: windshield wiper problem... never seen anything like it before (riceisnicenv)
BUMP... where are the EF gurus?
Old Dec 10, 2004 | 03:29 PM
crexer's Avatar
i have the same exact problem as well
Old Dec 10, 2004 | 03:34 PM
garlic jr's Avatar
Default Re: windshield wiper problem... never seen anything like it before (crexer)
make sure the screw is down all the way on the arm.
does your batt light come on when u drive and or lights get brighter at night when u gas it ? jw
Old Dec 10, 2004 | 03:38 PM
SETI20's Avatar
The arms are connectred to each other and the motor. Sounds like there's play on the shaft. It's a real bitch to get to it tho.
Old Dec 10, 2004 | 03:40 PM
.Noah Fecks's Avatar
Default Re: windshield wiper problem... never seen anything like it before (garlic jr)
turn the wiper blades power to the off position.
place them in the right position.
tighten the bolt down that connects the arm to the motor.
turn them on to make sure they stop in the right place on the up pass.
Old Dec 10, 2004 | 05:09 PM
drdisco69's Avatar
Default Re: windshield wiper problem... never seen anything like it before (Noah *****)
The wiper linkage may be broken, it uses plastic bushings on the end that often wear out, making them go wild like you're describing. If you take off the cowl you can move everything around and get a better look. If any of the linkages have any play, replace it, you can't get a new bushing.
chrisna
Nov 12, 2007 08:42 PM
MikeDawg
Jul 18, 2007 02:03 PM
PhilMac
Jun 17, 2007 02:09 PM
jdmturbo1127
10
May 25, 2007 06:48 PM
whiteef-8
22
Sep 12, 2005 07:40 PM
