What airbox after swap GSR
I know it sounds weird but I like the OEM look. Except for my HAsport style mounts and my ugly wiring my swap looks like it came that way from the factory. CTR cast exhaust manifold, CTR cat converter, dual core rad, etc.
One of the things I am having a problem with is the air filter hose and box. I have a CRX Si airbox but I can't get any hoses to route to it. Part of my problem is that I am using the stock GSR manifold.
Any options?
I really don't want to run a cold air intake.
Any options?
Some of the guys here used an Integra XSi intake arm (Wes V) and (Droppedcrxsi) I used an aftermarket Akimoto intake on my Gsr swap.
i changed out the intake manifold and am now using the skunk 2 manifold with a xsi intake tube with the stock 91 si airbox. it looks clean. got the idea from droppedcrxsi.
I have a skunk2 manifold as well and I'm running a 90 integ LS arm with the stock CRX airbox (had to hacksaw off part of the tube that comes out of the box.. it was a bit too long)
i have a spare XSI intake arm if your interested, and the airbox too! i dont think it has a filter though, ill have to check... PM me if your interested.
i'm running the stock gsr manifold. the fuel filter was in the way, so i shimmed it down with some door hinge parts (
) from the hardware store, and then i went to the junkyard and pulled a few acura intake arms. I came back and cut one to fit my setup.
bb4socal
19
Apr 21, 2010 08:59 AM
