Problem, help me out bro
i have a 99 em1 and this started to happen last night after i did a pretty big burnout in the rain while leaving work. Now when ever i try to turn right i feel some sort of reseistance and also it makes this weird popping kind of noise? what could this be? This is on the passengers side of the car and in the back of the car whever i turn right there is like a creeking noise, its wierd. The noise comming from the back of the car has happened since i bought the car about 2 1/2 months ago. Any help would be greatly appreciated. thankyou
i have disc brakes....oh and now that you mention the parking brake, when i have my car sitting overnight with the e-brake on in the morning when i come out to my car and release the e-brake it makes some sort of wierd niose also. So now that you brought that up that might be one of the problems. thanks and other info or suggestions on what could be the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-starr* »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Stop bumping the ******* thread. You fucked up a CV joint in your axle and damaged a rear brake rotor. Check the brake assembly and get a new axle before you bump this again. Jesus Christ.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Stop bumping the ******* thread. You fucked up a CV joint in your axle and damaged a rear brake rotor. Check the brake assembly and get a new axle before you bump this again. Jesus Christ.</TD></TR></TABLE>
werd.......
werd.......
redpeppers
Sep 3, 2005 08:21 PM
FortunateFool.
May 21, 2004 06:09 PM
