Popping and turning (Don't dyou dare say axle!)
Old Dec 9, 2004 | 11:26 PM
rice_classic's Avatar
Default Popping and turning (Don't dyou dare say axle!)
I want opinions on popping and turning when it is NOT a bad axle.
Here's the deal, I have 2 good axles but I had "klunking" noise on the right side over not-so-smooth pavement. The problem was a ball joint... I don't know which ball joint because I replaced all 3. After I replaced all 3 ball joints the "clunking" was gone but now when I turn sharply and in both directions there is a popping or a "knocking" rap tap tapping from that corner of my car.
It happened after I replaced the ball joints so my question is... do ball joints makes this kind of noise? I have checked my work and everything looks good.
Any help would be appreciated.
Old Dec 9, 2004 | 11:33 PM
CRX_1.8T's Avatar
Default Re: Popping and turning (rice_classic)
It isn't the plastic lining on your wheel well, right?
Old Dec 10, 2004 | 12:15 AM
Default Re: Popping and turning (CRX_1.8T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T &raquo;</TD></TR><TR><TD CLASS="quote">It isn't the plastic lining on your wheel well, right? </TD></TR></TABLE>
nope.
Old Dec 10, 2004 | 12:55 AM
Redline9's Avatar
try lubing ur cv boots
Old Dec 10, 2004 | 05:14 AM
manson's Avatar
Default Re: Popping and turning (Redline9)
could the CV be binding? what axels are you running? what IM shaft? and what motor?
Old Dec 10, 2004 | 06:18 AM
joey1320's Avatar
Default Re: Popping and turning (manson)
try your sway links. i had the same problem with a Saturn LS 300... replaced the lt. front strut, intermediate shaft(there's a bulletin on that) and it was the freaking left sway link bushing... yeah my service manager wasn't happy after he spend all that money!
good luck!
Old Dec 10, 2004 | 07:49 AM
Recluse03's Avatar
how are your tie rods?
Old Dec 10, 2004 | 07:53 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Recluse03)
Don't rule out the inner steering rack ends. These are the balljoints under the boots on the steering rack. If those boots get torn, those things will wear out. Any unwanted play in the steering will make noises...
Old Dec 10, 2004 | 11:06 PM
Default Re: (94eg!)
For the question about the shafts.. I have a b16 with hasport mounts with teg int. shaft and axles and i've had them for 2 years and they have never been a problem.. this noise ONLY appeared AFTER I changed the 3 ball joints... the Lower, the Upper and the Tie rod.
I guess I could switch out tie rods and see if that's the culprit and I have had the boot get torn on the rack causing me to need to replace the bushing in the steering rack but I don't think it's the inner joint (I will check it next time I get the time).
As for the person that said sway links... that could be a certain possibility. I have the ES bushings in the sway links and they are over 2 years old (still in great condition upon inspection) but they will wear "together" a certain way and after I took them apart and put them back together that could certainly be causing it... Good deduction..
Ok, This gives me something to look forward to. I actually wouldn't mind it if it was the axle because those can be fixed really easy and I can do it in 30 minutes... The "mystery" sounds that can drive me crazy.
Old Dec 11, 2004 | 05:15 AM
slowpokesi's Avatar
Default Re: (rice_classic)
i have the same problem, but i havent replaced my ball joints but the axles are brand new, it was clicking before i put them in and its still clicking, only when turning right.
WhiteOnRice
14
Sep 26, 2006 10:16 AM
accordredliner
Dec 21, 2005 08:14 PM
KMk51188
14
Sep 2, 2005 06:31 AM
Honduh@Love
Aug 30, 2005 02:18 PM
GReddy SI
12
Jul 17, 2003 04:07 AM
