Do i need to upgrade my injectors??
Old Dec 9, 2004 | 11:08 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
Default Do i need to upgrade my injectors??
when i was trying to "tune" my new setup today, no matter how much i raise the fuel pressure, the afr is coming back up at around 5900 rpm, it goes from around 12.7 at 5900 to 13.8 around 7500
does this mean i have run out of injector???
Old Dec 10, 2004 | 12:10 AM
Eddiebx's Avatar
how much power are u making and what size injectors are you runing. but the only real way to measure it is to datalog the injectors on one of your dyno passes, then u can see how much duty cycle its pushing
Old Dec 10, 2004 | 12:29 AM
i am making 188 hp @ 7600 rpm, 7600 is the highest i took it due to the a/f ratio headed to the lean side
i am running stock 97 ex injectors
here is a link to the thread with my chart and mods https://honda-tech.com/zerothread?id=1080997
Old Dec 10, 2004 | 12:32 AM
anyway to datalog without piggyback, or standalone?
i plan on gong hondata, but i am still on the hunt for a virgin p72 obd1 i have a p28 but i don't want to lose my iab in my stock i/m
btw i am running a gsr
Old Dec 10, 2004 | 05:12 AM
BryanPendleton's Avatar
Default Re: (BrokeAssWhiteboy)
What are you tuning with? Just the AFPR?
Old Dec 10, 2004 | 06:02 AM
Eddiebx's Avatar
if i am thinking correctly, 97 EX injectors are about 240cc? if so they are definitely too small to be making close to 200whp. What you should look for is something in the mid 300 range. like a 340cc or a 370cc. then you should be good
Old Dec 10, 2004 | 06:54 AM
Default Re: (BryanPendleton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanPendleton &raquo;</TD></TR><TR><TD CLASS="quote">What are you tuning with? Just the AFPR?</TD></TR></TABLE>yeah and a innovate lm1 wideband in the tailpipe
pugdug808
Oct 31, 2016 04:34 PM
ben222
Aug 27, 2007 11:04 PM
slow_ls
11
Jan 16, 2007 08:46 PM
dkboyny11
Sep 28, 2005 02:39 PM
mafay2
Nov 12, 2004 08:24 AM
