A few problems with my newly installed zc(d16a1)
Old Dec 9, 2004 | 07:45 PM
91bluehatch's Avatar
Default A few problems with my newly installed zc(d16a1)
Well my buddie and I recently installed my fresh Zc(d16a1), but I cannot seem to find a starter that will work with my si tranny and d15 flywheel, I figured the d15 starter wouldve worked but that wasnt the case, does anyone have a clue to as wat starter will work? Also I cant find a header thatll fit the motor/car combination, anyone know where i could get one? thanx
Old Dec 9, 2004 | 07:49 PM
Nevaeh's Avatar
Default Re: A few problems with my newly installed zc(d16a1) (91zchatchback)
from what i hear, the parts for a zc are almost non existant or hard as hell to find.
mrspeaker's Avatar
A d16a1 is not a zc motor..
A zc motor has zc stamped on the block..There is a dohc zc,sohc zc,and sohc vtec zc..And a zc motor is j-spec
The d16a1 is the **** motor from the us 87-89 integra..And it doesnt even bolt to the 88-91 chassis like the zc does..It does however bolt up to the 84-87 civic/crx
Just lettin you know..
Old Dec 9, 2004 | 07:55 PM
doublethink's Avatar
you sure its a d16a1 man? if so then get an old integra starter, 87-89 that will do the trick mr speaker is right.
so did you weld this thing in there, bc a real d16a1 wont bolt into a 91 hatch and theres no mount application....
Old Dec 9, 2004 | 07:58 PM
Default Re: A few problems with my newly installed zc(d16a1) (doublethink)
Its in there. So a older integra starter will work? Ill get some pics up soon and show yall how a d16a1 goes into a hatch.
Old Dec 9, 2004 | 09:18 PM
Vandemar's Avatar
The 86-9 Integra (the car the D16A1 came in) starter will work....if you're using a CG tranny, which has an intermediate shaft, 20-spline input shaft, and weird mounts (compared to an 88+ Civic). Take the engine back out, buy something that'll bolt to your car, and sell the A1 to someone with an 84-7 car.
I'm wondering how you dealt with the timing-belt side engine mount, what with it being on the front of the block and all...
Old Dec 13, 2004 | 09:39 AM
JKingCivicSi's Avatar
Default Re: A few problems with my newly installed zc(d16a1) (Nevaeh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nevaeh &raquo;</TD></TR><TR><TD CLASS="quote">from what i hear, the parts for a zc are almost non existant or hard as hell to find.</TD></TR></TABLE> Im about to put a zc in my civic. Is this gonna be a problem? What happens if my starter burns out? Nobody makes parts for it?
Old Dec 13, 2004 | 09:47 AM
QUiKSR20's Avatar
Default Re: A few problems with my newly installed zc(d16a1) (JKingCivicSi)
There is 2 diff ZC ( DOHC ) Motors and 2 Diff D16A1 ( DOHC )
Brown top and black top. Newer ones are usually found swapped
into 88-91s and the older style ones were swapped into older 1G CRX
and 3rd gen civics there both ZCs and both DOHC just mount diff etc..
Hope this helps you just need the right one for the right application.. Almost
all dohc parts from the 86-89 integ work and there is lists out there of what
parts you need for your car just search.. Good luck
Old Dec 13, 2004 | 09:57 AM
Doug684's Avatar
Please post picks as soon as you get them. I want to see this.
Old Dec 13, 2004 | 11:24 AM
Outsane's Avatar
Default Re: A few problems with my newly installed zc(d16a1) (Doug684)
any d series starter should work fine if you have a ZC
Old Dec 13, 2004 | 08:15 PM
Arsenal's Avatar
Default Re: A few problems with my newly installed zc(d16a1) (Outsane)
Well my friend just bought a 89 Teg, and the engine is a D16A1.
What are the specs on this engine?
Thanls
Old Dec 13, 2004 | 08:51 PM
mrspeaker's Avatar
Default Re: A few problems with my newly installed zc(d16a1) (Arsenal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">Well my friend just bought a 89 Teg, and the engine is a D16A1.
Thanls</TD></TR></TABLE>
d16a1 comes in the 86-87 integras ..
9:5:1 compression ratio..
113hp @6250 rpm
99lb/ft @5500 rpm
d16a3 comes in the 88-89 integra
9:5:1
118 @5500 rpm
103 lb/ft @5500 rpm
Old Dec 14, 2004 | 09:20 AM
Arsenal's Avatar
Default Re: A few problems with my newly installed zc(d16a1) (Mrspeaker)
Thankyou.
Old Jan 7, 2010 | 05:23 PM
bori21's Avatar
New User
yea put some piks up
Old Jan 11, 2010 | 06:36 PM
PtownCivic's Avatar
I just bought a 90 civic hatch with a D16A1 from japan, there killer engines. Gonna boost it soon. But any D series starter should work just fine
Old Jan 12, 2010 | 04:37 AM
Sikocivic's Avatar
Show us pics. D16a1 will NOT bolt into 88-90 Civic/CRX. You would need custom made mounts. Lets see pics of the motor in your car and pics of the ID stamp on the block.
Old Sep 6, 2010 | 11:30 AM
staticchmbr's Avatar
d16a1 came in the USA integras 86-89
Civic Hx-T
34
Jun 17, 2016 09:29 PM
BG-Teg
Mar 4, 2007 09:49 AM
stemiched
Nov 15, 2006 12:20 PM
South Bay Surfer
Aug 20, 2004 05:36 PM
zc crx
11
May 26, 2002 10:05 PM
