Radioshack wires for vtec?
Old Dec 9, 2004 | 07:38 PM
B16aCRXSi's Avatar
Default Radioshack wires for vtec?
To better explain the topic, I have a 92 Integra RS with a 1st gen jdm B16a w/ J1 tranny. I've been running my stock LS ecu for awhile and finally bought a p61 off of a fellow h-t member. I haven't gotten the ecu yet because i just bought it. Now for my question...I'm planning on running the vtec wires myself from the engine bay to the ecu. Can I buy wires from RadioShack to run them from the engine (vtec wiring) to the ecu? If so, what size or what specific type of wiring do i need? Thanks for the information in advance.
Old Dec 9, 2004 | 08:31 PM
eda6's Avatar
Default Re: Radioshack wires for vtec? (92DA9B16a)
Do you need ecu pins/engine harness plugs? For the wire i'd use stranded 16 ga.
Old Dec 9, 2004 | 08:45 PM
B16aCRXSi's Avatar
Default Re: Radioshack wires for vtec? (eda6)
I think I may need ecu pins. Are they all the same? How much do they cost at the Honda/Acura dealer?
Old Dec 9, 2004 | 09:10 PM
eda6's Avatar
Unfortunately Honda/Acura doesn't sell the pins. Your best bet would be a junkyard. Plan B is ht classifieds.
If you get lucky at the junkyard
I know where some ecu pins are at my local junkyard. PM me if you want me to get them for you.
Old Dec 10, 2004 | 12:16 AM
dylokjai's Avatar
i had the same motor on my previous 4dr teg and i was running on LS ecu for a while....i dont remember the site/link on DIY vtec DA w/b16 but i got all my pins and wires from radioshack...
Old Dec 10, 2004 | 03:21 AM
bigTom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">Do you need ecu pins/engine harness plugs? For the wire i'd use stranded 16 ga.</TD></TR></TABLE>
16awg is way too big... u dont need anything bigger than 20awg
Old Dec 10, 2004 | 08:51 AM
B16aCRXSi's Avatar
Default Re: Radioshack wires for vtec? (ek9t)
thanks for the info I can get pins from Radioshack? The same ones that go into the ecu?
Old Dec 10, 2004 | 10:53 AM
LudeyKrus's Avatar
I don't think you can get the pins from Radioshack. There are ways of making it work w/ just the end of the wire jammed in the harness plug, but they don't work too well.
Get 22 or 24 gauge wire from Radioshack, I believe 24 is what I used. It is what you want to use. Just run the wires from the ecu to the engine compartment, and put some terminals on the wires to connect them to the solenoid/pressure sensor so that you can remove them easily.
Old Dec 10, 2004 | 11:30 AM
dylokjai's Avatar
Default Re: (LudeyKrus)
yes they carries PINS IE for like Radio/cdplayer harness wiring PINS(same as ecu pins i think (i used it and it works) AT RADIOSHACK...
Old Dec 10, 2004 | 09:01 PM
B16aCRXSi's Avatar
Default Re: (dylokjai)
thanks
Old Dec 11, 2004 | 07:39 AM
bigTom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you can get the pins from Radioshack. There are ways of making it work w/ just the end of the wire jammed in the harness plug, but they don't work too well.
Get 22 or 24 gauge wire from Radioshack, I believe 24 is what I used. It is what you want to use. Just run the wires from the ecu to the engine compartment, and put some terminals on the wires to connect them to the solenoid/pressure sensor so that you can remove them easily.</TD></TR></TABLE>
i dont think u can get the pins from radio shack either... uinless someone happen to fina some pics that happen to fit in the plug...
oh... and i hate to just keep saying what guage is wrong... but 24awg is to thin... id use 20awg... 22awg imo is too thin as well
EGCIVICKING95
Aug 30, 2011 05:03 AM
SOLEpassion
Mar 27, 2010 04:30 PM
MM's94Civic
Jun 30, 2004 08:59 PM
ThePro
Feb 5, 2003 05:42 PM
