Dented header!!!
Old Dec 9, 2004 | 06:58 PM
KiNG $h!t's Avatar
Default Dented header!!!
Potholes suck. Today i hit a big *** bump and put dent in my jdm itr 4-1 header. Now right before the collector it has about a 1 and a half inch dent. Is there anyway to fix a header?
Also i have been driving it and i cant really tell right now, but it kinda seems like i have lost some top end how bad do you think this is choking my motor? Forgot to add i got a dent in my oil pan. How bad is it to run a dented oil pan?
Old Dec 9, 2004 | 07:30 PM
DOHCsideracing's Avatar
Default Re: Dented header!!! (this guy 2fast)
I've never actually done this, but it seems like you could take a small section of mandrel bent tubing of the same material, diameter, thickness, and bend radius, cut out the bad section of the header, and weld the new section in. It prolly won't be perfect (since the weld penetration will upset the internal walls a little), but it will be way better than what you have.
Anyone ever tried this?
Also, I have seen motorcycle headers get fixed by slidehammering the dented area out. Basically you drill some small holes in the header, and put some small screws in them, slidehammer that screw until the shape is returned,a nd weld over the holes. I think those headers are usually thinner, so that might not be possible with a 16ga header...
Adrian
Old Dec 9, 2004 | 07:32 PM
KiNG $h!t's Avatar
thanx for the info anyone else?
Old Dec 9, 2004 | 07:38 PM
hOndafienD 04's Avatar
i dont think you can fix it...at least i wouldnt attempt....you should sew your city...but then again most likely your car is dropped and they are gonna use that against you..sorry to hear man
Old Dec 9, 2004 | 09:04 PM
KiNG $h!t's Avatar
bump.
boosted k20's Avatar
Default Re: (hOndafienD 04)
i wouldnt worry about it too much. i have flatened out my 4-1 header a bit, but not too drastically. havent noiticed any power loss.
Old Dec 9, 2004 | 09:19 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (boosted k20)
Don't worry about the header, it sucks but there probably isn't much you can do... Unless you can heat it up with a torch and pull it out, like you would a dent on a car body. - As for the oil pan, make sure the oil pickup wasn't damaged, and make sure the pan isn't up against the pickup.
95_red_dc
Sep 22, 2008 10:23 AM
Elbowpunk
Mar 20, 2006 02:42 AM
superdupervtec
Aug 6, 2005 06:04 AM
junbb1
Mar 24, 2004 05:43 AM
