Car not starting is my timing off???????
Okay let me start I put a DOHC ZC in my EJ1 (93 honda civic coupe) and it iis the OBD0 engine with the ODB1 wire ..It was working fine last week but then it wouldn't start..I took apart the distributor and the rotor was broken. I replaced the rotor and the car started fine and was working fine but when I reached like 3,000RPM the car would break up and seem as if it was lacking fuel. I checked the fuel and it was fine...then I realized the spring from the coil pack was gone so i used some foil paper for the time being...when I did that the car worked as before but it would do the same thing as before but now at a earlier RPM like 2000 we checked the idle and cecked the fuel but it would do the same...then on my way home from my friends house it decided to die....I tried to push start the car several times and It will not work. I took off the pipe off the intake manifold and when I try to start it a flame comes out the IM but the motor does not start...I givewhen i give it gas nothing happens...and I keep fouling the spark plugs...I bought them last week drove the car about twice and the plugs are black......Here are the specs the motor has about 60k Miles on it its a dohczc with a t3/t4 turbo with a vortech Fmu, adjustable fuel pressure regualtor...The only codes Im throwing are 21 22 and 41 Please help me if you can......I've only had the motor in for about 3 weeks....and all its done is cost me money...please help me before i go crazy and set this $hit on fire!!!!1
fresh99si
Aug 3, 2009 05:56 AM
NewBorn_EG
11
Nov 24, 2004 06:20 PM
TiggsCRX
94
Jul 11, 2004 12:57 PM
