Will my 98+ front bumper wobble at high speeds?
Old Dec 9, 2004 | 06:02 PM
Integgin's Avatar
Default Will my 98+ front bumper wobble at high speeds?
Hey guys, im new here to Honda-Tech....ive got a couple questions....Im doing a 98+ conversion on my 94 integra....I did a search, and i do know all i need is the 98 front bumper, headlights, and turn signals...I have some questions that i need to be answered though if u guys can help me....
I actually had a fiberglass front bumper *body kit* on my car, and i threw the foam away from my front bumper...
Heres the questions..
1. Will my 98+ front bumper wobble or move around at high speeds since i threw my foam support from my 94-97 away? Or should i just bolt the bumper real tight, and stick somethin in there thats kinda homemade?
2. Will all brackets, bolts, and everything else from my original 94-97 front fit when i do the 98+ conversion?
3. 98+ Front bumper, 98 headlights, 98 turn signals...Is there anything else i am missing at all that is NECESSARY to complete this conversion? Even if its a small screw to buy, will u guys let me know...Thanks
Old Dec 9, 2004 | 06:35 PM
confucius's Avatar
Default Re: Will my 98+ front bumper wobble at high speeds? (Integgin)
I don't have the foam on my front beam either. Nothing wrong from what I can tell. Everything is a perfect fit. Some people say you need a 98 hood. but I don't think you do.
Old Dec 10, 2004 | 12:34 AM
rovigian's Avatar
Default Re: Will my 98+ front bumper wobble at high speeds? (confucius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucius &raquo;</TD></TR><TR><TD CLASS="quote">I don't have the foam on my front beam either.</TD></TR></TABLE>
That foam slows down the impact time in a front end collision, so it has some purpose.
Old Dec 10, 2004 | 06:14 AM
ebelp's Avatar
Default Re: Will my 98+ front bumper wobble at high speeds? (rovigian)
Definitely try to replace the styrofoam when you do the conversion. Any styrofoam will work....just ziptie it to the bumper reinforcement bar.
Old Dec 16, 2004 | 09:17 PM
confucius's Avatar
Default Re: Will my 98+ front bumper wobble at high speeds? (ebelp)
Yeah, the dealer wants 100 or so for $2.00 woth of molded styrofoam.
my bumper is missing the syro and it does not wobble at all.
Modified by confucius at 11:32 PM 12/16/2004
Old Dec 16, 2004 | 10:20 PM
tC_Dragon's Avatar
i don't think it will really wobble if u bolt it down well and get the bottom bolts that go onto the radiator support as well. But i would jsut go to a salvage yard and pick up one of those foam things... probably wouldn't charge you too much... plus u can get any foam from 94 up not jsut 98-01.
Old Dec 17, 2004 | 12:10 AM
Wht-Blk dc2's Avatar
highly doubted that it would wobble or anything at all.
Old Dec 17, 2004 | 04:19 AM
MikeTV
Guest
Posts: n/a
Default Re: Will my 98+ front bumper wobble at high speeds? (Wht-Blk dc2)
im not running any bumper support at all and I also have th e98 conversion; the bumper cover is just fine. Just make sure you screw down all of the holes on the top under thehood, and tighten the screws at the edge of the bumper that connect to the fender
Old Dec 17, 2004 | 10:58 AM
dwolsten's Avatar
I don't think wobbling is a problem without the styrofoam. The problem is that it's there to protect the bumper from damage in minor collisions. Suppose someone backs into you in a parking lot. With the styrofoam there, it'll absorb the shock, and your bumper will probably flex a little. Afterwards, you probably won't even be able to tell the car was hit. However, without the styrofoam there, there'll be a big void behind the bumper, and this will probably just cave in if someone hits it, effectively ruining the bumer.
I do agree about the pricing, however. Something like this should be ultra-cheap. Maybe you could use a knife and some glue and make your own from the compressed styrofoam pieces used frequently for shipping.
Old Dec 17, 2004 | 11:11 AM
calxtreme's Avatar
I don't think it will wobble either. Just make sure you have all the brackets. I did a 98 conversion on mine but during the process I realized that the 98 bumper did not have its signal brackets and the 95 ones don't fit. Where the heck would you get those brackets cheap anyways?
Old Dec 17, 2004 | 01:24 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">That foam slows down the impact time in a front end collision, so it has some purpose.</TD></TR></TABLE>
yeah, but it's only for collisions under 5mph. anything over that and we're screwed anyway.
Old Dec 17, 2004 | 01:52 PM
Stripped Si's Avatar
Default Re: Will my 98+ front bumper wobble at high speeds? (LSvtec03)
Styrofoam between your bumper and hood latch helps prevent thieves as well.
Old Dec 17, 2004 | 02:35 PM
xprohx's Avatar
I think too much
Default Re: Will my 98+ front bumper wobble at high speeds? (Stripped Si)
My buddy who is also missing the foam has a little wobble when you flex it. But it was seen the road yet so I don't know about high speeds.
LilTeggy2011
Mar 22, 2010 10:28 AM
Ratchback
Mar 9, 2006 12:23 PM
AznMTboy
May 14, 2005 06:45 AM
hondamanwill
Sep 11, 2002 06:31 PM
bhang
Jan 10, 2002 09:10 PM
