MPFI SWAP -- hELP
Old Dec 9, 2004 | 05:09 PM
shivern's Avatar
Default MPFI SWAP -- hELP
Yo wasup, well when i went to wire my CAS, i noticed that B10 and B12 were not empty... what could be there? should i just cut them anyway? or is there supposed to be wires there -- it seems like most of the guides say "Pin B10 and B12 should both be empty.", well if they are empty wouldnt you have to get 2 more extra pins?
if anyone could help pleasee doo
btw its a 1990 DX HB
Old Dec 9, 2004 | 05:24 PM
shivern's Avatar
Default Re: MPFI SWAP -- hELP (shivern)
bum p
Old Dec 9, 2004 | 05:52 PM
shivern's Avatar
bump
Old Dec 9, 2004 | 05:54 PM
dr_latino999's Avatar
Are you sure you're at the right pin location? My LX harness with all its extra nifty features did not include pins at 10 and 12, but double check to make sure you are at those locations. When I did my wiring, I erred once by assuming I was somewhere I wasn't and cut the wrong wire. Needless to say that set me back like five minutes but it is still the measure twice, reference five times, measure again, reference again and cut once rule. If there are still wires there in B10 and 12, chop those bastards. They don't do anything
Old Dec 9, 2004 | 07:00 PM
civickiller's Avatar
Default Re: MPFI SWAP -- hELP (dr_latino999)
i would double check and make sure your looking at the rigth spot ? mine had a wire at one of them, i forget which, but the instructions say that you might have that wire there
Old Dec 9, 2004 | 07:16 PM
shivern's Avatar
my homie had this and it REALLY is all i need, thanks fellas
Old Dec 10, 2004 | 12:06 AM
jdmdude's Avatar
I'll remember that for next time.. The EDIT BUTTON!!! Thanks HONDA-TECH GURUS!!!
Modified by jdmdude at 11:18 PM 12/10/2004
Old Dec 10, 2004 | 04:19 AM
Default Re: MPFI SWAP -- hELP (jdmdude)
You could have just linked to the page rather then COPYING AND PASTING the source code.
Old Dec 10, 2004 | 06:51 AM
tweakit's Avatar
AGREED
Old Dec 10, 2004 | 09:03 AM
HiGH PSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">You could have just linked to the page rather then COPYING AND PASTING the source code.</TD></TR></TABLE>
LMAO!!
How did it go? Got the wiring correct?
Old Dec 10, 2004 | 09:33 AM
shivern's Avatar
Default Re: MPFI SWAP -- hELP (b00st Happy)
today i'll figure it all out, hopefully
Old Dec 10, 2004 | 11:06 AM
jdmdude's Avatar
sorry guys, I thought honda-tech would pick up the source, and paste it on their site... Next time.. I will do that...
Old Dec 10, 2004 | 11:08 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdude &raquo;</TD></TR><TR><TD CLASS="quote">sorry guys, I thought honda-tech would pick up the source, and paste it on their site... Next time.. I will do that... </TD></TR></TABLE>
How about an edit?
Old Dec 10, 2004 | 11:36 AM
jdmdude's Avatar
Default Re: MPFI SWAP -- hELP (DaX)
Sounds good dude, I will edit next time... Here is the link... http://www.fourthgenhatch.com/mpfi.html
Old Dec 10, 2004 | 11:45 AM
Well you can still edit it now, you see that little button right next to reply?
Old Dec 10, 2004 | 12:30 PM
DCI VW's Avatar
so doing it that way doesn't require an ecu swap, correct? or does it?
if so, does the PM7/ZC unit work in place of the MPFI/Si unit?
Old Dec 10, 2004 | 12:52 PM
Default Re: MPFI SWAP -- hELP (DCI VW)
The PM7 would work.
Old Dec 15, 2004 | 10:20 AM
shivern's Avatar
OK im having so much trouble depinning B2!! what do i do!!
Old Dec 16, 2004 | 12:25 PM
DaX's Avatar
DaX
Loved
Community Favorite
If you're interested, HASport carries an OBD-0 depinning tool for like $35.
ryanevansoh
Mar 27, 2009 04:06 PM
dafro42
Jan 2, 2007 05:53 AM
Markis.
Mar 21, 2006 08:18 PM
ef_Racer
Jun 13, 2004 02:45 PM
