EK Civic Cooling Problems, pls HELP!!!!
Old Dec 9, 2004 | 05:01 PM
Honcivic97a's Avatar
Default EK Civic Cooling Problems, pls HELP!!!!
Heres the deal, I rear ended someone and have been rebuilding my car. I installed a brand new fluidyne radiator new hoses thermostat, I replaced the wiring harness etc.... Basically the rad fan will not turn on and I checked the fuses the relays, and the thermostat. My temp gauge goes to hot 10 seconds after I turn on the car. I bled the cooling system, My AC compressor and fan are not hooked up yet, but I don't think that could be the problem. PLEASE HELP ME!!!!!!!
Old Dec 9, 2004 | 06:08 PM
v.i.gsr's Avatar
Default Re: EK Civic Cooling Problems, pls HELP!!!! (Honcivic97a)
If your car is getting hot that fast, its probably your tempurature sensor thats bad.
Modified by v.i.gsr at 1:08 PM 12/11/2004
Old Dec 9, 2004 | 08:57 PM
RedHB..D15B's Avatar
Default Re: EK Civic Cooling Problems, pls HELP!!!! (v.i.gsr)
your gauge cluster <U>could</U> be fucked up...i remember in my old hatch i had a cluster in which the temp would suddenly go all the way up to "H" and stay there. I thought it was my thermostat, when i replaced it it didnt fix the problem. Later i changed the cluster and then it was fine.
Old Dec 9, 2004 | 10:26 PM
Lenthrax's Avatar
Default Re: EK Civic Cooling Problems, pls HELP!!!! (RedHB..D15B)
heres something to check
theres a temp sensor on the housing of the thermostat..jump the connector and it should turn on; if it does, it could be the sensor
Old Dec 12, 2004 | 04:50 PM
v.i.gsr's Avatar
Default Re: EK Civic Cooling Problems, pls HELP!!!! (Lenthrax Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lenthrax Performance &raquo;</TD></TR><TR><TD CLASS="quote">heres something to check
theres a temp sensor on the housing of the thermostat..jump the connector and it should turn on; if it does, it could be the sensor</TD></TR></TABLE>
thats what I was trying to tell the kid. hahaha!!!!
Old Dec 16, 2004 | 12:42 PM
Thanks I'll try that Hopefully it will work
Old Dec 16, 2004 | 01:20 PM
all stock's Avatar
if your fan won't turn on, try hooking the fan up during to the battery to see if it spins. if not, try replacing the fan switch.
JENNY_EG6
13
Jun 19, 2012 05:16 PM
phoxking
Apr 28, 2010 08:58 PM
Fighterinsnatch
Jul 20, 2007 01:27 PM
HondaHemi
Apr 30, 2006 10:49 PM
Jaesung
Jul 1, 2003 09:14 AM
