92 Gsr in a 88 crx
Old Dec 9, 2004 | 04:44 PM
rollin111's Avatar
Default 92 Gsr in a 88 crx
Has anyone have a 92 Gsr in a crx? i am going to put one in but just wanted to know if it is a good swap to do.. and what kind of problems i might have..
thanks
Old Dec 9, 2004 | 04:52 PM
mrspeaker's Avatar
Default Re: 92 Gsr in a 88 crx (rollin111)
Its a good motor but its obd1 so you'll either have to convert your car to obd1 or convert the motor to obd0..
But other than that its like putting in a b16...
and comes with one of the best geared B-series trannys
Old Dec 9, 2004 | 04:57 PM
rollin111's Avatar
Default Re: 92 Gsr in a 88 crx (Mrspeaker)
I got the engine with a sir tranny, soo will that still be ok?
Old Dec 9, 2004 | 04:59 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollin111 &raquo;</TD></TR><TR><TD CLASS="quote">I got the engine with a sir tranny, soo will that still be ok?</TD></TR></TABLE>
That will work. If you can, get a usdm s80 tranny with lsd. Same gear ratios as s1 but alot stronger because of dual synchros and it has a lsd.
go obd 1. You won't have to deal with the two o2 sensor bs.... Distributors will be easier to find.
Get the hasport cable to hydro kit.
GSR+CRX= happy you
Modified by eda6 at 10:42 PM 12/9/2004
Old Dec 9, 2004 | 05:02 PM
mrspeaker's Avatar
Yeah,as long as its a cable tranny...
Old Dec 9, 2004 | 05:05 PM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
That will work
go obd 1 get a p72 so the iab's will function correctly. You won't have to deal with the two o2 sensor bs.... Distributors will be easier to find.
GSR+CRX= happy you</TD></TR></TABLE>
He's talkin about the 92-93 gsr motor ..not the 94-01 motor..
And they come with cable tranny so there is no need to convert to hydro..
he says he has the sirI tranny which is cable also so dont get him confused..
Old Dec 9, 2004 | 05:10 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">
he says he has the sirI tranny which is cable also so dont get him confused..</TD></TR></TABLE>
I wasn't trying to confuse anyone. i just think that a itr hydro tranny would compliment the motor and the car. That's all.
Old Dec 9, 2004 | 05:18 PM
rollin111's Avatar
Default Re: 92 Gsr in a 88 crx (eda6)
Would a hydro tranny be better??
Old Dec 9, 2004 | 07:22 PM
fourthgenhatchB17's Avatar
I say u just drop the motor in now as it is with a cable tranny. No need to confuse this matter than it already is for him. Oh, and you should convert the car to obd-1.
Old Dec 9, 2004 | 07:23 PM
doublethink's Avatar
yes, but its not cheap. he explained why its better.
if the tranny you have now doesnt grind, you can use it, and cheap out on the mounts too, since the hydro tranny requires the more expensive kit from hasport.
you can do it either way, one is much more expensive.
Old Dec 9, 2004 | 07:25 PM
Mefain's Avatar
i have a b17 in my CRX....love it to death...wouldnt give it up for nething.....i converted to obd1 stayed everything stock....and its definatly stronger than a b16 if you ask me....if you got it, drop it without even second guessing yourself....make sure you use a ys1 cable tranny to compliment the motor
Old Dec 9, 2004 | 07:59 PM
ImportRicer's Avatar
nice..good luck
Old Dec 9, 2004 | 09:15 PM
Deetz's Avatar
Crazy Honda Guy
What the heck are you talking about? The engine is a B17A, there are no iab's. The B17 is a stroked B16 and shares the same intake manifold.
Old Dec 9, 2004 | 09:39 PM
eda6's Avatar
Default Re: 92 Gsr in a 88 crx (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">
What the heck are you talking about? The engine is a B17A, there are no iab's. The B17 is a stroked B16 and shares the same intake manifold. </TD></TR></TABLE>
I need to pay more attention
busychild
27
Sep 2, 2016 02:28 PM
Zatzy
Nov 18, 2004 07:18 PM
spcrxracer
Jun 2, 2004 07:41 AM
TeamSTEALTH GSR
May 28, 2003 09:22 PM
Carp
Dec 14, 2002 05:41 PM
