PLEASE HELP!!!! searched
Old Dec 9, 2004 | 03:51 PM
wpgcivic's Avatar
Default PLEASE HELP!!!! searched
i have a stock swap d15b7 into my 94 eg hatch and the timing is now lined up perfect but when i try to manually turn the crank it turns for a bit then its like it hits something and wont go any further, any ideas?
Old Dec 9, 2004 | 04:00 PM
wpgcivic's Avatar
ttt
Old Dec 9, 2004 | 04:11 PM
Luserkid's Avatar
Default Re: (wpgcivic)
Dumb question, is it in gear and is the car on the ground?
Old Dec 9, 2004 | 04:27 PM
wpgcivic's Avatar
the car is not in gear and yes its on the ground
Old Dec 9, 2004 | 04:28 PM
cappa's Avatar
Double check timing sounds like it could be a open valve and its hitting the pistion
Old Dec 9, 2004 | 04:30 PM
wpgcivic's Avatar
could it be a bent valve by any chance?
Old Dec 9, 2004 | 04:36 PM
cappa's Avatar
Can you see if they are all comming up all the way? Or look to see what pistions at the top down the spark plug hole and then look at the set of valves to see if there is one stuck open or something
Old Dec 10, 2004 | 07:33 AM
fathergoose's Avatar
Default Re: (cappa)
make sure the up mark on the cam pulley is up and that the two small lines line up with the head, make sure that the big white line on the crank pulley is lined up with the viser in the lower timing belt cover
Old Dec 10, 2004 | 12:39 PM
wpgcivic's Avatar
yeah timing is done properly and its still doing this
Old Dec 10, 2004 | 12:46 PM
Del Sol SiR's Avatar
Default Re: (CivicTECH36)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicTECH36 &raquo;</TD></TR><TR><TD CLASS="quote">nice way to help someone out *******
I guess you're the dumb one</TD></TR></TABLE>
Trial User flaming He was asking him a dumb question...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Dumb question, is it in gear and is the car on the ground?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">the car is not in gear and yes its on the ground</TD></TR></TABLE>
Old Dec 10, 2004 | 01:05 PM
wpgcivic's Avatar
but in all reality what does that have to do with the crank not turning all 360 degrees?
Old Dec 10, 2004 | 01:54 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
do you have the plugs out of it?
Old Dec 10, 2004 | 02:02 PM
wpgcivic's Avatar
did it both with the plugs in and out of the engine why, what would the difference be?
PY2KITR1060
Jul 26, 2022 06:12 AM
alex14
12
Sep 29, 2010 01:01 AM
d16trex
Aug 23, 2010 03:03 AM
MugenHonda
Jun 17, 2005 05:19 PM
Kirt Porter
Oct 8, 2004 09:10 PM
