94 vtec vs. 94 si exhaust, whats the difference
where talking about #18 in the pic, the B pipe
whats the major difference between the b pipe of an vtec and of an si, the have a different part number, but i was wondering whats the difference,
diameter, resonator difference? cat flange, anyone have any information,
if someone could post up some specs of the h23 B pipe i have the h22 b pipe, but need to compare them, and find the difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 »</TD></TR><TR><TD CLASS="quote">they look physically the same to me....maybe the h22 is 1/8th of an inch bugger diameter?</TD></TR></TABLE>
totally different part number.
honda would have used the same part on two of thesame types of cars unless they had a good reason not to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnbb2 »</TD></TR><TR><TD CLASS="quote">they are both exactly the same except for a different flange where it bolts to the header
well, thats atleast truefor aftermarket exhausts, so if your question is can i put a vtec aftermarket exhasut on my si? yes</TD></TR></TABLE>
not worth it since the only deffernces are the flanges
Guest
Posts: n/a
not worth it since the only deffernces are the flanges</TD></TR></TABLE>
yea but some companys wont make exhaust for the si/s models so im jsut stating that you CAN use the vtec model exhausts
no a friend wanted to hack up my b pipe cuz it just sitting around, i want to save it, so i figured i would ask and see why the si and vtec are diferent because i probably could ge my hand on an si one much easier than a vtec model stock exhaust
Here is all you need to know:
Flanges are different, length is different...
However, remember that companies DO make cats in differing lengths...
Using that logic, it's a simple matter of getting a cat the length you need...
I am re-using my Thermal once my H22 goes in here soon, I'm just going to weld up a quick-n-dirty test pipe, take measurements, and then order a car-sound cat at the length and diameter I need, along with any flanges I need. Then when they arrive, it's a simple matter of welding it all up, and bolting it in...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 »</TD></TR><TR><TD CLASS="quote">yeah i'd like to see pics myself just to see the length differences....pirate used a h22 b pipe with h23 header on the g23....he might have something...</TD></TR></TABLE>
I used a DC h22 b-pipe with DC H23 primaries. On my exhaust system NOTHING is OEM.
Pirate
Pirate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred »</TD></TR><TR><TD CLASS="quote">
Pirate</TD></TR></TABLE>
now did you use a h22 or h23 cat or are they the same flange?
when you say you used the h22 b pipe are you refering to the same b pipe as i am in my first posted picture
or are you talking about #8 in the picture above?
im guessing you used the h23 upper portion of the header, then h22 lower portion with h22 cat back?
Well like I said. Nothing on my exhaust is OEM. I have a 2.5"X14" adustable testpipe. so I have the adjustability to go with headers of different lengths. When I bought my car I had no intake, NO exhaust, no interior carpet, no passenger side seat, no AC, fuxored H23 block, Fuxored power steering and the list continues. It took a lot of work to get back to looking like a decent POS.
Pirate
Pirate
