LS cams in a ZC?
Old Dec 9, 2004 | 01:07 PM
sleepin91teg's Avatar
Default LS cams in a ZC?
I have a LS motor, b18a1, and have the 403 crower cams for that motor...i also have a ZC motor can i swap the 403 cams into the zc?!
Old Dec 9, 2004 | 01:25 PM
hondaguyef's Avatar
Default Re: LS cams in a ZC? (sleepin91teg)
I am pretty sure it won't work but, May I ask why you would want to do this?
Phil
Old Dec 9, 2004 | 01:27 PM
Default Re: LS cams in a ZC? (hondaguyef)
Got the cams in a motor with a blown bottom end...and i have a running zc in my hatch...maybe put the cams in
Old Dec 11, 2004 | 11:14 PM
Turbo(less)DB8's Avatar
Pretty sure it won't work. the dohc zc is basicaly the same as a usdm d16a from a first gen teg.
Old Dec 12, 2004 | 03:10 AM
havok hybrid's Avatar
Default Re: LS cams in a ZC? (nscivic)
search on this tpoic more.. i heard valve terain can be swaped... not sure if that means cams too..... but there is info out there somewhere
also.. TIP... to run a d16 SI Distrubtor on a DOHC ZC.. run a LS cam cap.. where the dissy bolts up .. ***
Old Dec 12, 2004 | 07:03 AM
v4lu3s's Avatar
RTFM
usually teh cams match teh bore spacing pretty well on an engine since the valves match the bore spacing too. last i knew the D had a smaller bore
than a B series....meaning the broes are closer together.
jaycorolla
Jan 23, 2013 09:10 PM
89 pos
Mar 27, 2005 11:56 AM
DaMmniTz
Feb 4, 2005 11:47 PM
Shiro Z31-T
Feb 4, 2005 01:01 PM
sabertooth
Sep 1, 2003 04:44 PM
