Can a P30 ECU work a D16Z6?
Old Dec 9, 2004 | 12:27 PM
b17gsr's Avatar
Default Can a P30 ECU work a D16Z6?
We are swapping a B16 into a 92 Civic Si this weekend. My buddy is swapping his P28 ECU for a P30. Will the P30 ECU be able to get his D16Z6 started and moved into my garage? It will simply be idling/1500 rpm. We'd push it in, but impossible with the amount of ice in my driveway.
His D16Z6 is already screwed up, so as long as it won't screw up the ECU, we are happy.
TIA!
Old Dec 9, 2004 | 12:29 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Can a P30 ECU work a D16Z6? (b17gsr)
Should work fine yea.
Old Dec 9, 2004 | 01:25 PM
Deemeetree's Avatar
Electrician
Is he trading the ECU or does he still have it? If he still has it, why not use the P28?
Old Dec 9, 2004 | 01:37 PM
b17gsr's Avatar
Default Re: (Dimi)
The plan was to keep the P28 and chip it, but there's a longer than acceptable delay, so he found someone that's willing to do a trade.
Old Dec 9, 2004 | 01:57 PM
Jimmy's Avatar
Global Moderator
It will work good enough for you to pull the car up in the garage.. other then that i wouldn't drive it with the p30.. incorrect fuel map's,etc.
goodluck
1sickeg8
Dec 4, 2009 10:07 AM
sc95delsol
Oct 16, 2007 05:23 PM
TehMoonRulz
Apr 4, 2005 06:38 PM
dynamicauto
Jul 7, 2003 04:20 PM
Aaron Taylor
Sep 29, 2002 01:55 PM
