sun roof hard to close
Old Dec 9, 2004 | 12:13 PM
lsvteccoupe's Avatar
Default sun roof hard to close
i have a 92 civic si and the sun roof is har to open and close you can push up on it when trying to open it and it will open easyer and then closeing it you have to push on it as you push the button i was just wondering if there is some adjustment for it
Old Dec 9, 2004 | 12:16 PM
sohcvtec1995's Avatar
Default Re: sun roof hard to close (lsvteccoupe)
Mine dose the same thing. it could just be off some. At least thats what i think, cause i have had to replace mine cause it feel off track or something like that
Old Dec 9, 2004 | 01:44 PM
93CivicSI's Avatar
motor is getting old - I have the smae problem with mine. Will most likely buy a junkyard motor this spring.
Old Dec 9, 2004 | 02:50 PM
alotawatts's Avatar
Roof Motor clutch ?
Old Dec 9, 2004 | 03:04 PM
silverEH2's Avatar
Default Re: sun roof hard to close (alotawatts)
roof motor going bad or rails need to be cleaned
Old Dec 9, 2004 | 03:54 PM
Soccerking3000's Avatar
Default Re: sun roof hard to close (silverEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 &raquo;</TD></TR><TR><TD CLASS="quote">roof motor going bad or rails need to be cleaned</TD></TR></TABLE>
ya make sure all the rails are clean them lube them and it should work alot better, mine did
Old Dec 9, 2004 | 04:22 PM
Default Re: sun roof hard to close (Soccerking3000)
thanks for the help it a pian in the *** ill try to clean the rails and hope that helps
Old Dec 9, 2004 | 04:27 PM
Just get some silicone spray, and it should help out.
Old Dec 9, 2004 | 04:54 PM
DAguyLS's Avatar
check the small springs the run along the rails. If one of them isn't connected it makes it almost impossible to go any further than cracked open a little bit
Dizzypop DA
Dec 3, 2007 03:21 PM
ImportechPerformance
11
Dec 13, 2004 11:39 AM
projektCRX
15
May 2, 2004 07:07 PM
Chrislow
15
Feb 22, 2004 09:39 PM
