B18a mounts?
i need to know if i can use the stock mounts out of my 92 civic lx, i have searched for hours, and also anyone recomend any exhaust manifold, turbo flanges, gonna run a t25 dsm turbo
Your timing belt side mount and the top tranny mount off of your d-series motor will work if your putting your motor into a 5th gen., and i'm not sure about the other gen. You need to find the lower front tranny mount, rear tranny mount, and the lower mount near your timing belt(a/c mount). Make sure that the rear mount is for a b18A not a b18B because those two mounts are different. Try searching again because I know someone has a diagram for this swap.
well its a 93 civic ls and im putting a 91 B18a in it with 70k on it, then getting a custom tubular exhaust mainifold with a dsm t25 and custom side dsm side mount intercooler for now, im just looking for what mounts im gonna need i know i need a b series tranny, b series axles, and b series shift linkage, but mounts??? i will continue searching but anymore info would be extremely helpful picking up the motor in 2 days
not trying to be a dick to you bigboostersx but keith just did this swap like not even a month ago. so he knows what you need to change over. and i apoligize in advance if i miss read the posts.
Ecky
10
Jun 7, 2013 11:07 AM
Razr2
18
Mar 15, 2008 08:59 PM
onyx00
Sep 24, 2004 01:00 PM
