TPS voltage is fine but still surges
Hey all I read all the bad idle problems and I wanted to know something else. I tested everything and i tested my tps and the voltage was .51 closed but if the tps is disconnected it doesnt surge anymore. Even though the voltage is reading correct can that still mean the tps is bad?
Thanks
Thanks
Yes, it still could be bad. Not that expensive, just replace it... You could also have a bad throttle body or wiring issue or bad ecu...
Honda will only sell you the WHOLE throttle body w/TPS for like $500. Get a TPS off of ebay, but that's probably still not the problem. I bet you have a vacuum leak.
nah there is no hissing or vac leak. i replaced all the hoses anyways... but when the tps is unpluged, it stops surging, but also like I said the voltage is correct so i dunno if it really is the tps or not so i just drive around with the tps unpluged.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prolink »</TD></TR><TR><TD CLASS="quote">Yes, it still could be bad. Not that expensive, just replace it... You could also have a bad throttle body or wiring issue or bad ecu...</TD></TR></TABLE>
I agree. Just replace it b/c they are not to much $. But make sure you have no vacum leaks first.
well if you can get around town with it disconected, then i'd do it unill i had the new one.....like prylwd said they are not too expensive....but i think you have to get them straight from honda or ebay
Br1anPham
May 31, 2009 06:23 AM
