All Motor Exhaust Dillema.. ( help )
Im just about finished with my car. ( 89 CRX Si w/01 GSR ) Ill list my mods
and then i will tell you what im unsure of.
01 GSR Swap w/hydro trans
no emmisions equipment
JDM 4-1 Header
skunk2 intake manifold ( port matched )
Bored TB ( max bore 64 )
type r cams
chipped p28 OBD1
clutch & flywheel
full suspension
z10 oil pan
z10 traction bars
aem intake for 99Si
My question is what would be the better for my exhaust im a little confused.
Either skunk 2 ( pre made exhaust ) or custom 2.5 from kteller w/hks hiper
muffler and a resonator. Im shooting for strictly performance i wasnt going
to make the extra bend and just exit the pass side.
So its either skunk2 2.25 mandrel or custom 2.5 im leaning towards the 2.5 this is just a weekend fun street car. I just want to get the best for the power I will be making.
Thanks in advance ill include a pic for views
Modified by QUiKSR20 at 3:58 PM 12/9/2004
JDM 4-1 Header
type r cams
chipped p28 OBD1
clutch & flywheel
full suspension
z10 oil pan
z10 traction bars
aem intake for 99Si
do a custom side dump 2.5 with a nice resonator in there thats PERFORATED CORE. louvered cores suck so bad and people still stock and use them at most exhaust shops!
my cherry bomb was perforated core and thus had 0 restriction and very low generation of turburlence. the same cannot be said for a louvered core.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm »</TD></TR><TR><TD CLASS="quote">do a custom side dump 2.5 with a nice resonator in there thats PERFORATED CORE. louvered cores suck so bad and people still stock and use them at most exhaust shops!
my cherry bomb was perforated core and thus had 0 restriction and very low generation of turburlence. the same cannot be said for a louvered core.</TD></TR></TABLE>
So def go 2.5 ( thats what i was thinking ) and make sure I get a perforated core right?
Anyone else? opinions suggestions ?
Thanks
Thanks
if you want peak power i would do 2.5" . i would personally stick with skunk2, for it has been R&D'd for your car and would be good for midrange as well.it will also fit perfectly with no rattles or rubbing. that's my opinion
Yeah i hear you on fit up.. but im going for all out performance. Eventually this
will have a built motor in it.. So far 2.5 seems the way to go thanks guys.. Keep it coming!!! I chose the HKS HIPER over the Apex N1 for better sound out of the same style of muffler.
LOL well that would be too much ehehhe its still a street car Its registered and insured and i like to drive it besides just at the track heheh.. Im just looking for the best all around exhaust for HP ( besides none heheh )
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Si »</TD></TR><TR><TD CLASS="quote">I'd go with the 2.5" because that still leaves you some room to add more mods.
deff
deff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QUiKSR20 »</TD></TR><TR><TD CLASS="quote">I chose the HKS HIPER over the Apex N1 for better sound out of the same style of muffler.</TD></TR></TABLE>
just curious and not trying to flame, but what makes you think that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ef9 »</TD></TR><TR><TD CLASS="quote">im runnin kteller 2.5" stainless w/ n1 muffler on my all-motor gsr ef hatch!
*also a 2.5" test pipe*</TD></TR></TABLE>
Heard the car at an H-T meet, and seen it run at the track and i like the kteller w/n1 setup hes running.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 »</TD></TR><TR><TD CLASS="quote">
Heard the car at an H-T meet, and seen it run at the track and i like the kteller w/n1 setup hes running. </TD></TR></TABLE>
y thanks you!!! how've you been? haven't talked to you in a little while?
Pretty close to what I have: 2.5" custom piping w/ Apex N1 and 2.5" testpipe on an allmotor LS EH Hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Corb »</TD></TR><TR><TD CLASS="quote">
I just heard a few friends civics with N1 setups and a few with Hipers and
without cats i thought the HKS sounded better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ef9 »</TD></TR><TR><TD CLASS="quote">y thanks you!!! how've you been? haven't talked to you in a little while?</TD></TR></TABLE>
Im good dude, finally got my car running right, just in time to park it for winter heh.
Hows your car been? I was at the track the at the test and tune when u were running, right towards the end of the season. You were getting a lil quicker every pass.
Didnt know if u wanted me posting your times and traps here, but what did u end up running that night?
Either way to stay on topic, hes got a quick car, and he was pulling some good times running thru the exhaust. (right??)
Did u ever try to run w/o the exhaust?
Did u ever try to run w/o the exhaust?</TD></TR></TABLE>
no open header passes yet!!! im savin that for next year. ive got a few more tricks up my sleeve for next year also
. im really impressed with the way the car runs... not bad for oem bottom end! but yes, my exhaust setup performs pretty well! kteller
diazeg92
Aug 5, 2012 02:06 PM
