custom intake maniflod?
Old Dec 9, 2004 | 11:03 AM
DXK Eg's Avatar
Default custom intake manifold for b-series?
where can i find a b-series intake manifold flange . I want to make manifold that looks some what of a STR or Venom ?? Any idea where i can find one ...
Old Dec 9, 2004 | 01:29 PM
Turbo-charged's Avatar
Default Re: custom intake manifold for b-series? (dynasty-x-motorsport)
most people cut a stock one......
Old Dec 9, 2004 | 02:07 PM
ExploitedRacing-HR's Avatar
Default Re: custom intake manifold for b-series? (Turbo-charged)
I dont have those avialable yet but if you were to send me the gasket i could cut a new one from 6061 aluminum.
Old Dec 9, 2004 | 02:32 PM
.dave's Avatar
i HAS questions ?
I'd try contacting the guys from Full-Race as they are making a big push towards making intake manifolds. I'm sure they can help you out quite a bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExploitedRacing &raquo;</TD></TR><TR><TD CLASS="quote">I dont have those avialable yet but if you were to send me the gasket i could cut a new one from 6061 aluminum.</TD></TR></TABLE>
The only problem is what are you going to do about the injector angles/location from just a gasket?
Old Dec 9, 2004 | 03:28 PM
hmm good point... I always forget that hondas and a few other makes put there injectors in the intake manifold instead of the head... Most engines i work with arent like that.
Well, i do have a machine shop so i suppose i can make something work but i would need a stock intake manifold first then.
Old Dec 9, 2004 | 04:01 PM
.dave's Avatar
i HAS questions ?
Default Re: (ExploitedRacing)
Here's my idea. Pretty easy to do especially if your CNC can't mill at an angle that would work.
Just bolt the flange to the block/bracket, set the spacing for the centerlines of the injector holes, diameters etc. I'm sure theres information on the angle somewhere online and everything else shouldn't be difficult to measure.
Old Dec 9, 2004 | 05:46 PM
DXK Eg's Avatar
Default Re: (d@ve.G)
so is it better to just buy one then making it? because of the injectors i also forget about them..because it looks kind of ugly when you cut the stock one and add to it?? or i have a idea but don't know if it will work??you can weld a small round tube with a washer inside it ,so the injectors won't leak and try to fit the fuel line on
{ there will be alot of cutting and porting to the flange in this case }.. I think it might work just get new seals before you start i guess ???but i need a stainless steel one?? Because i don't know of the hardware stores around here sells aluminum sheets. So if you guys are sure you can make me a flange out of steel. Let me know and i'll send you the $$..
thanks
Old Dec 9, 2004 | 08:41 PM
I can cut at angles.
Old Dec 10, 2004 | 07:39 AM
DXK Eg's Avatar
so can you make me a steel flange ?? Do you still need me to send you a gasket for a b18c intake manifold?
Old Dec 10, 2004 | 10:11 AM
I could make the flange out of anything really. And yes i would need the gasket if you just want a plain flange without the injector pieces.
Old Dec 10, 2004 | 04:23 PM
Archidictus's Avatar
Unceasing Measure
If you're not afraid of moving **** around, you'll actually gain some power and gas mileage from relocating the injectors further away from the combustion chambers. Don't be afraid
Old Dec 10, 2004 | 04:59 PM
snoochtodanooch's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">If you're not afraid of moving **** around, you'll actually gain some power and gas mileage from relocating the injectors further away from the combustion chambers. Don't be afraid </TD></TR></TABLE>
adjusting of timing needed?
Old Dec 10, 2004 | 06:40 PM
DXK Eg's Avatar
Default Re: (snoochtodanooch)
i guess i'll try it out..and since it will be made out of steel i'll have to use that new hondata gasket..
Old Dec 11, 2004 | 07:10 AM
H23vtecEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExploitedRacing &raquo;</TD></TR><TR><TD CLASS="quote">I could make the flange out of anything really. And yes i would need the gasket if you just want a plain flange without the injector pieces.
ive been making them for a while now check my sign. no need to send im gasket
Old Dec 12, 2004 | 08:32 PM
Dov's Avatar
Dov
I have one at home! I bought it at the beginning of the season and did not end up using it. It is 60/61 Aluminum CNC flange. $100
Old Dec 13, 2004 | 07:06 AM
rhd's Avatar
rhd
Default Re: custom intake manifold for b-series? (Dov)
JG uses the stock runners....it seems to work well, and should come out a little cheaper for you.
here's my JG mani:
also, you might want to contact Brad@RLZ......he might be able to help you out
Old Dec 13, 2004 | 07:41 AM
JMFabrications's Avatar
Could you just weld injector bungs into the runners right by the flange?
Old Dec 13, 2004 | 08:17 AM
essex's Avatar
Default Re: custom intake manifold for b-series? (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">
For these types of manifolds what do you end up doing with the iacv?
Old Dec 13, 2004 | 09:53 AM
Casey's Avatar
Default Re: custom intake manifold for b-series? (essex)
he doesnt have an iacv
Old Dec 14, 2004 | 04:12 AM
rhd's Avatar
rhd
actually......i do, but it's just not hooked up to the mani. it's ziptied to the firewall right beside the catch can......so it wont throw a code.
you can make it fit, just fab up a plate like the ITB guys are doing lately....i might do it myself, just to see if it changes idel any.
weiRtech
Welding / Fabrication
10
Oct 19, 2007 02:57 PM
h22aBB4
Jan 6, 2007 06:34 AM
E-AT_me
Oct 30, 2006 08:56 AM
mister2racer
Aug 10, 2005 03:36 PM
EdLeake
17
Feb 23, 2004 09:08 AM
