white smoke out of my exhaust on a 2000 civic si
Old Dec 9, 2004 | 08:58 AM
HONDA RR's Avatar
Default white smoke out of my exhaust on a 2000 civic si
I have a 2000 civic si and a lot of white smoke come out of my exhaust. Does anyone know why?
Old Dec 9, 2004 | 09:06 AM
primeredbeast's Avatar
Default Re: white smoke out of my exhaust on a 2000 civic si (MITSUBA)
does it burn any oil check it
Old Dec 9, 2004 | 09:07 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
a lot of white smoke? most likely head gasket. good luck.
Old Dec 9, 2004 | 09:10 AM
00Red_SiR's Avatar
All Motor Mentor
Does it do it all the time or does it go away when the car warms up?
IS ypur car going through any oil or coolant but not leaking on the ground?
Need this information to help you.
Old Dec 9, 2004 | 09:33 AM
HONDA RR's Avatar
Default Re: white smoke out of my exhaust on a 2000 civic si (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Does it do it all the time or does it go away when the car warms up?
Need this information to help you.</TD></TR></TABLE>
It comes and goes, and at high rpm's it appears a lot more at times but not always.
Old Dec 9, 2004 | 09:34 AM
HONDA RR's Avatar
Default Re: white smoke out of my exhaust on a 2000 civic si (smithenhiven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smithenhiven &raquo;</TD></TR><TR><TD CLASS="quote">yeah, white smoke is usually associated with burning oil. </TD></TR></TABLE>
It actually burns more gas than oil. The oil is pretty much consistent.
Old Dec 9, 2004 | 09:36 AM
Frozen E's Avatar
H-T White Ops
White smoke - coolant
Blue smoke - Oil
Black smoke - Fuel (running rich)
Old Dec 9, 2004 | 09:38 AM
smithenhiven's Avatar
11:11
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">It actually burns more gas than oil. The oil is pretty much consistent.</TD></TR></TABLE>
well even a little burning oil can cause smoke like that. As mentioned above, it could be a headgasket, and coolant is getting into the engine. Maybe try the seafoam stuff that people have been using lately, maybe it's a carbon build problem, and if so, the sea foam will take care of that. Just an idea.
00Red_SiR's Avatar
All Motor Mentor
what about coolant level??
Old Dec 9, 2004 | 09:40 AM
endlesswinterco's Avatar
Default Re: white smoke out of my exhaust on a 2000 civic si (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">
Blue smoke - Oil
Black smoke - Fuel (running rich)</TD></TR></TABLE>
at least someone got it right. check your coolant levels, deff, headgasket, but make sure that its white and not blue.
11:11
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">White smoke - coolant
Blue smoke - Oil
need to edit my post now.
Old Aug 3, 2016 | 03:15 PM
Sogs_em1's Avatar
My car does that whats is the problem
Old Aug 3, 2016 | 07:28 PM
eghatch9295's Avatar
Stancetard Hate Monger
deeerrrrrrrrrrrrrrrrrrrrrrrrrppppppppppppppppppppp pppppppp
Old Aug 3, 2016 | 11:03 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
A 12 year old thread....
Rule of thumb for Honda-Tech..... Create your own thread with your relevant car information and reference this thread you found. That way diagnosis of your specific car can commence and we can look at this reference thread for examples of the behavior your car is doing.
Every car is different and should not be lumped together with another car and it's issues.
And it's bad form here at H-T to bring back ancient threads from the dead. Database space is not an issue so there is absolutely no reason to bloat one thread with crap loads of cars of similar issues to have to sort through in hopes to find some relevant information.
/thread put back to bed.... permanently.
ELSUICIDA
13
Apr 4, 2007 06:07 PM
Baodalazi
Jan 15, 2007 07:18 AM
DeviousCTR
Nov 7, 2006 11:52 PM
redDAinteg
Jan 9, 2006 04:57 PM
blitzteggsr
May 11, 2004 04:08 PM
