crazy question PLEASE HELP!
i have an 89 crx hf with a b18a in it. i used the factory hf motor harness and when the car is running the check engine light and my brights light are on. when i turn my lights on my factory shift light comes on. i told everyone this is a crazy question and thanks in advance for all the help.
J.D.
J.D.
sounds like your wiring is not done correctly, otherwise this wouldn't happen. There must be a place where the wires short causing this problem.
not if your brights and shift light are coming on. Those arent controlled my the ECU. I'm thinking main relay. Thats gona be a nightmare, so good luck
good luck bro. that sounds like one hell-of-a-shitlist growing. The relay is behind the little coin drawer thingy on the driverside. The shift light comes on and you have a b18a.? interesting. Are you thorwing codes. I would say have a look at all the in chasis wiring and test all the Connectors....and track down your problem.....**** dude....good luck.
cybertek12
Mar 22, 2004 04:13 PM
