JRSC Si Brakes!!!!!!!!
well i have a JRSC civic Si and im looking for a brake kit, i have been looking on the web and i found some kits but to much money.... so im looking for a good 4 piston caliper system that is not to expensive...
or does someone has any other idea feel free......
thanks
sergio.
thanks
sergio.
This kit has called to me for some time now. It is one of the same kits offered at fastbrakes, but for way less money. Without the slotted/drilled rotors, its only 530, and has everything you need. The only problem is you'll need at least 16" wheels (and only certain 16s fit). This comes w/ free shipping, free adjustable proportioning valve (custom install required), forged calipers, stainless brake lines, and use of saftey wire pliers (w/ deposit). This system also sheds 6lbs (I think) from each hub...
Part number 140-6163
http://www.hotrodsusa.com/store/dbbfront_hat.html
