93 h23 obd1 to 99 h22obd2
Old Dec 9, 2004 | 06:58 AM
techart's Avatar
Default 93 h23 obd1 to 99 h22obd2
Hey i am doing a swap from my h23 to an h22 Most everything is going good exept none of the wire harneses match am i supposed to modify that or how does that go i also got a p13 ecu for the vtech any advise with the swap greatly appreciated. thanks
Old Dec 9, 2004 | 10:25 AM
mgags7's Avatar
you should use your h23 wiring harness......just wire up the extras to work.....vtec....etc...
but you will need an obdI distributor on there....your h23 one will work great.....and im sure others know but i think you will need an obd1 intake manifold off an h22.....
[shameless plug] i have an obd1 h22 intake manifold, jdm and has 24k on it....let me know if you want it.....[/shameless plug]
Old Dec 9, 2004 | 01:58 PM
techart's Avatar
Default Re: (mgags7)
I was told that if i get the p13 ecu i wouldnt need to swap my distributor. but where i am stuck at is is that none of the wires from the h22 distributor connect to the ones on my engien bay the ecu goes under the dash on the passengers side and that connects prefectly but i have to run 2 more wires for the vtech to work so basicaly i am just trying to figure out if anyone has a diagram of how to rig up the wire harnesses.
Old Dec 9, 2004 | 02:37 PM
mR. Vash's Avatar
Default Re: 93 h23 obd1 to 99 h22obd2 (techart)
it's "Vtec" with no H....Thanks.
Old Dec 9, 2004 | 03:37 PM
prelittlelude's Avatar
well use your h23 harness, splice on some obd2 injector clips, use the h22 290cc injectors, use your obd1 distributor, run some wires for vtec, and get a odb1 to obd2 addapter
98_ssbp
Sep 25, 2014 10:15 PM
Johnrb
Sep 13, 2010 06:23 PM
meanshyguy
Feb 2, 2009 05:49 PM
crownsk8er
Dec 1, 2006 07:41 AM
skylude23
Oct 21, 2005 04:10 AM
