Expected 1/4 mile?
Well after doing some heavy thinking between turbo and NA and being confused to no end, I want to know what kind of 1/4 I can expect if I do the following setup
Built D16Z6 (eagle rods), Lightened Flywheel, 10.X:1 CR(A6 pistons?)
Individual throttle bodies, ZEX Cam, 55Shot Wet Nitrous+water/alcohol injection to raise octane levels for the track, NGK Iridium Plugs, Header and 2 or 2.5 inch exhaust and last but not least Uberdata or hondata with 9000 RPM limit and some tuning using wide band O2.
Remember that I will be spraying between 4-9k and the reason I want to go all motor is I dont think turbo is all that especially since it will lag alot. I want to get them off the line and then use my ZEX and 9k RPM limit to my advantage.
also what CR ratio will A6 pistons in a Z6 yield?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules »</TD></TR><TR><TD CLASS="quote">2.E. Posting e-racing threads in EG+ Civic / Del Sol is not allowed. Any thread that asks “Which car will win?” or “What will my car run with xxxx mods?” will be locked immediately. Do not post these threads unless you have a timeslip or dyno graph and can back up your claim with concrete information.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_guy_83 »</TD></TR><TR><TD CLASS="quote">also what CR ratio will A6 pistons in a Z6 yield?</TD></TR></TABLE>
~10.5:1
~10.5:1
Xgen
Dec 9, 2004 09:28 AM
z6
Jul 1, 2004 06:04 PM
