T3 Super 60 Coolant Lines
Old Dec 9, 2004 | 03:03 AM
civiceg500's Avatar
Default T3 Super 60 Coolant Lines
I have an oil cooled and water cooled T3 Super 60 turbo, I was wondering where can i find a kit? How would i go about putting one on?
Old Dec 9, 2004 | 12:32 PM
civiceg500's Avatar
Default Re: T3 Super 60 Coolant Lines (civiceg500)
anyone?
Old Dec 9, 2004 | 12:40 PM
Sonny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiceg500 &raquo;</TD></TR><TR><TD CLASS="quote">I have an oil cooled and water cooled T3 Super 60 turbo</TD></TR></TABLE>
Sure you do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> I was wondering where can i find a kit? How would i go about putting one on?</TD></TR></TABLE>
You can look for an OEM watercooled T3 from any Volvo, Saab, or Ford Thunderbird. Easier yet is to use barbed NPT nipples.
Sonny
Old Dec 9, 2004 | 12:42 PM
civiceg500's Avatar
Default Re: T3 Super 60 Coolant Lines (Sonny)
Do you have any idea of where to connect the lines?
Old Dec 9, 2004 | 12:43 PM
EJ1 wilcox's Avatar
You don't really need to water cool the turbo just because it has a jacket...
But if you really want to, just tap into a coolant line. I haven't ever seen any kind of kit for this... maybe I'm wrong though...
Old Dec 9, 2004 | 04:25 PM
civiceg500's Avatar
Default Re: T3 Super 60 Coolant Lines (EJ1 wilcox)
Well, When i look at the turbo, It has four holes in bearing housing or the center housing. Two are for oil and two are for coolant. Could i plug the coolant holes or do i really have to run coolant?
Old Dec 9, 2004 | 05:23 PM
Just Checking In's Avatar
He already told you above that you don't have to run coolant through it to operate without harm. Where did you get your super 60 from, I understand they are pretty hard to come by. If you bought one off ebay that said "BRAND NEW GENUINE GARRETT SUPER 60...NEW NOT REBUILT BUY IT NOW $385" You probably got a rebuilt standard .60.
Old Dec 9, 2004 | 05:59 PM
civiceg500's Avatar
Default Re: T3 Super 60 Coolant Lines (Just Checking In)
Well, I bought it from a guy who said it was a super 60, let's just call it a 60 then. What do you mean run without harm? Do i keep the plugs in the water holes? I need more info.
Old Dec 9, 2004 | 06:26 PM
dc2legend's Avatar
I would hook up the coolant lines, they are there for a reason...it helps keep the turbo cooler.
Old Dec 9, 2004 | 06:28 PM
dc2legend's Avatar
Default Re: T3 Super 60 Coolant Lines (dc2legend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just Checking In &raquo;</TD></TR><TR><TD CLASS="quote"> Where did you get your super 60 from, I understand they are pretty hard to come by. </TD></TR></TABLE> There not too hard too find, especially if you're into turbo mopars, or you know people who are.
Old Dec 9, 2004 | 09:12 PM
By without harm, I mean that generally all the turbo needs to last a fairly normal lifespan is the oil connection to lubricate the essential components inside the center housing. The water jacket around it is an attempt to help keep the housing slightly cooler, but is not necessary. You can just put an appropriate sized bolt from the hard ware store in the openings if you want a more proffesional look, or just leave them open....it doesn't matter. It was just another way for the engineers to gain a little more efficiency in a very easy way.
If you do hook them up, make sure you do a good job of it, and bleed any air bubbles out of the system by getting the car up to operating temperature after the fan comes on, making sure the open rad cap neck is the highset point in the system, and filling it with coolant so the level does not fall below the radiator top as it bubbles out.
Modified by Just Checking In at 10:33 PM 12/9/2004
shredmanant
Dec 9, 2013 10:04 AM
SiHater
Sep 21, 2006 08:06 PM
PhatBoy5015
May 26, 2006 09:40 AM
InTeGrA B18b1
Apr 25, 2003 04:54 PM
inspyral
Jul 25, 2002 10:12 PM
