no spark from distributer
Old Dec 9, 2004 | 12:31 AM
BOMBCRU's Avatar
Default no spark from distributer
im working with a 90 accord with a f23 motor
3 distributers tried none are putting spark out(aint no way all 3 are bad)
2 are 90 accords the other is a 99 accord
tried out the power source the black/yellow it has full power
i then swapped in a obd2b (what came with the motor) and that is only 4 wires
yellow/green ICM IGNITER
yellow CYP
black/yellow POWER
drk blue RPM LEAD
IT STILL HAS FULL POWER TO THE BLACK/YELLOW
but i can stil not start the car or geta spark. i know the distributer works
ANY IDEA'S??????
is there more than 1 wire that is supposed to have power into it to start car?
Modified by BOMBCRU at 2:04 AM 12/9/2004
Old Dec 9, 2004 | 02:37 AM
The_Todd's Avatar
Farts in the shower
Default Re: no spark from distributer (BOMBCRU)
F23 is internal coil right?
If so I would test your coil .
Old Dec 9, 2004 | 10:47 AM
BOMBCRU's Avatar
Default Re: no spark from distributer (VR)
its internal coil, but ive tried 3 distributers and i know the one is definitly good
Old Dec 9, 2004 | 12:53 PM
bill-71SS's Avatar
do you have a pulse at the injectos?if not,look at the ecm
Old Dec 9, 2004 | 04:42 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOMBCRU &raquo;</TD></TR><TR><TD CLASS="quote">its internal coil, but ive tried 3 distributers and i know the one is definitly good</TD></TR></TABLE>
When you say dizzy do you mean the entire dizzy component including the ignition coil? I know those coils are pretty finiky, I would test it first...check your mechanic book for testing guidelines .
Old Dec 9, 2004 | 10:07 PM
BOMBCRU's Avatar
been doing a little digging into it
i have 2 codes comign up one is the o2 (not installed)
the other is IACV not plugged in code?
original motor had a 2 plug iacv i got a 3 plug on the new motor so i disgarded the black wire and tied to corinating colors
Old Dec 9, 2004 | 10:40 PM
BOMBCRU's Avatar
well i seen 3 wires that just didnt belong under the dash so i fallowed them to under back seat and behold a LO-JACK thats engaged might hinder a car from starting if activated(battery off car for a few weeks)
behold
http://ww.cardomain.com/id/ftpracing
Old Dec 9, 2004 | 11:05 PM
BOMBCRU's Avatar
still dont fawking work
Old Dec 9, 2004 | 11:30 PM
BOMBCRU's Avatar
ok i pulled the cap off and used the test light when i touched the YELLOW/GREEN that baby lit that ingiter up light lighting bolt to the motor
whats going on here???? do i need to repin this or something?? or ground it out???
honda_lx
Mar 26, 2014 01:04 PM
levi1dayAWDlude
Feb 20, 2013 02:27 PM
x19trix72x
Sep 30, 2008 04:43 PM
GrnZ
Mar 29, 2008 03:41 PM
jimbo090757
Nov 27, 2007 07:09 AM
