Guess at whp???
Old Dec 8, 2004 | 10:01 PM
JDMstance99's Avatar
Default Guess at whp???
I know this is kinda vague. But i am tryin to reach my goal of 190- 200 whp in a 99 civic si.
Civic type r b16b motor
skunk 2 stage 2 cams
ecedy clutch
prolite flywheel
mugen head gasket (buumps compression up to 11:2)
fpr
skunk 2 cam gears
hondata 200 and lots of tuning
wut u guys think?
can i reach it...if not wut else?
Old Dec 8, 2004 | 10:03 PM
mtber's Avatar
All I can tell you is you need to stroke that b16b to 1.8L :-)
Old Dec 8, 2004 | 10:12 PM
anothersickhatch's Avatar
Default Re: (mtber)
you are probably in the 170-175 range...thats my best guess. a stock b16b will put out about 150-160, plus cams and a little compression and tuning, and you are PROBABLY looking at around 175.
im just giving you a guesstimate...someone let me know if im wrong.
Old Dec 9, 2004 | 08:57 AM
Default Re: (anothersickhatch)
Ahh im still stuck on which cams to go with, toda spec A's or skunk 2 Stage2..
Modified by JDMstance99 at 10:28 AM 12/9/2004
Old Dec 9, 2004 | 11:18 AM
BlueTeg01's Avatar
Default Re: (JDMstance99)
what header do you have....exhaust..
Old Dec 9, 2004 | 07:29 PM
Default Re: (BlueTeg01)
jap spec type r header with apexi n1 exhaust...soon to be mugen twin loop
Old Dec 9, 2004 | 09:02 PM
MikeSarr_GSR's Avatar
put more cam in it like s3s, or Rocket's new M22s with the stock-ish primaries, clean up the head a bit, put a ITR or AEBS manifold on there. I bet you can see 185 or so then, but still the header, throttle body, injectors will be a restriction... a few details after that and 200 wouldnt be far away.
Old Dec 9, 2004 | 10:28 PM
UncleD's Avatar
Default Re: (MikeSarr_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote"> clean up the head a bit, </TD></TR></TABLE>
Did you know that a factory Type R head is already ported? Did you know that most head-work facilities do not recommend touching a Type R head(i.e. Portflow, Alaniz, Endyne, etc....)
I have a B16b in my car and am currently doing my homework. I have a Spoon exhaust/b-pipe with a J's racing test pipe, Spoon flywheel, Spec clutch and a Spoon headgasket in my car, and as far as I'm aware it gives me an even 11:1, a Mugen MAYBE gives you 11:1. You're gonna need more compression to run those Skunk 2 2's properley, Mugen twin loop is resrictive...may I suggest the Spoon N-1....sounds DELICIOUS! There is a H/T member on here who dyno'd his STOCK block jdm b16a with Jun 3's, keep in mind that the head was never milled, laid down 185 to the wheels. His name is "ghettoracer" and has a very strong motor. I'm a firm believer in Jun 3's, with those cams I think you could easily achieve your goal with maybe bigger injectors. Good luck man, keep us posted!!
Old Dec 10, 2004 | 12:36 AM
jdmsijdm's Avatar
why would you not want to port a type R head? a good head porter can run circles around honda's factory port job.
Old Dec 10, 2004 | 04:33 AM
1 2 NV's Avatar
Default Re: Guess at whp??? (JDMstance99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMstance99 &raquo;</TD></TR><TR><TD CLASS="quote">wut u guys think?
can i reach it...if not wut else? </TD></TR></TABLE>
i think this post needs to be deleted cause we are not here to bench dyno. further more these types of questions are clearly stated in the TOS to not be asked. do a search.
Old Dec 10, 2004 | 05:07 AM
AllMoToRB18c's Avatar
Default Re: Guess at whp??? (1 2 NV)
im guessin like 180
Old Dec 10, 2004 | 06:36 AM
civicgsr's Avatar
Default Re: (jdmsijdm)
A lot of people assume that porting the crap out of the head is where you get power. This is not true. Some of the best power gains are created by improving the shape of the bowl around the valve, not increasing the size of the port.
-Alex
Old Dec 10, 2004 | 08:53 AM
MaaseyRacer's Avatar
Just go to the dyno and find out. To just find out what you are putting down is cheap.
Old Dec 11, 2004 | 07:47 AM
Default Re: (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">
I have a B16b in my car and am currently doing my homework. I have a Spoon exhaust/b-pipe with a J's racing test pipe, Spoon flywheel, Spec clutch and a Spoon headgasket in my car, and as far as I'm aware it gives me an even 11:1, a Mugen MAYBE gives you 11:1. You're gonna need more compression to run those Skunk 2 2's properley, Mugen twin loop is resrictive...may I suggest the Spoon N-1....sounds DELICIOUS! There is a H/T member on here who dyno'd his STOCK block jdm b16a with Jun 3's, keep in mind that the head was never milled, laid down 185 to the wheels. His name is "ghettoracer" and has a very strong motor. I'm a firm believer in Jun 3's, with those cams I think you could easily achieve your goal with maybe bigger injectors. Good luck man, keep us posted!! </TD></TR></TABLE>
Thanks for all the info, I m going to talk to that guy, off the top of your head do you know if he upgraded his valvetrain with the jun3, even though the s2s2 might be more agressive, my compression might work better with the juns, like you said, anyway get bak to me
Old Dec 11, 2004 | 08:11 AM
sumyungguy's Avatar
where was all of this tunning done???? the tuning i know best is on a dyno with a wide band.... so if you've had "lots of tunning" you should have seen a dyno once or twice and then you should know your horse power.
Old Dec 11, 2004 | 08:13 PM
Default Re: Guess at whp??? (sumyungguy)
OEM ITR is a great head, but one of the head porters you quote performed the headwork on the OEM ITR head that went on the 11.3:1 200whp std bore B16 that was dynoed back in 10/2003. My only point is that the head can be improved upon and Tom @ Portflow did an excellent job Why use more compression than you need to make power? This peticular motor for example had an OEM head gasket, gen 1 B16 block with usdm spec pr3 pistons, .030" mill on the head, flat standard sized valves. The estimate was 11.3:1 cr, the setup was very rough and needed more tuning however, reaching 200whp from 1595cc in 5 days doesnt mean there werent any obstacles. A ported ITR head was one of the peices of this peticular puzzle. I hope all goes well with your build
Old Dec 12, 2004 | 12:17 AM
UnKnownUser's Avatar
Default Re: (civicgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr &raquo;</TD></TR><TR><TD CLASS="quote">A lot of people assume that porting the crap out of the head is where you get power. This is not true. Some of the best power gains are created by improving the shape of the bowl around the valve, not increasing the size of the port.
Old Dec 12, 2004 | 11:36 AM
Default Re: (LSVTEC_DC4)
especially on a 1.6
Old Dec 13, 2004 | 08:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">
i think this post needs to be deleted cause we are not here to bench dyno. further more these types of questions are clearly stated in the TOS to not be asked. do a search.</TD></TR></TABLE>
shutup, quit bitching little sissy, if you dont like it get out!
Old Dec 13, 2004 | 08:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumyungguy &raquo;</TD></TR><TR><TD CLASS="quote">where was all of this tunning done???? the tuning i know best is on a dyno with a wide band.... so if you've had "lots of tunning" you should have seen a dyno once or twice and then you should know your horse power.</TD></TR></TABLE>
im sayin if i have alot of tuning with hondata, because some people assume oh he has hondata he must be runnin, it all depends on the tuning
Old Dec 13, 2004 | 04:26 PM
1 2 NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMstance99 &raquo;</TD></TR><TR><TD CLASS="quote">shutup, quit bitching little sissy, if you dont like it get out! </TD></TR></TABLE>
alright ill answer ur question, NOT GOIN TO HAPPEN.
eat a dick and read the tos u moron.
Mashimaro
31
Jul 19, 2005 07:42 PM
TheOne
Mar 11, 2004 07:20 PM
Lost Type R
Feb 22, 2003 01:15 PM
MPH
Apr 22, 2002 11:45 AM
HXMan
Sep 10, 2001 03:47 PM
