Thermostat problem
Old Dec 8, 2004 | 07:57 PM
pisetup's Avatar
Default Thermostat problem
The temp would go up if I'm stuck in traffic and it would lower if I drive on the highway. So I bought a new thermostat. I just finished installing it about 30 minutes ago. I plugged everything back in and double checked that there weren't any unplugged wires. So I decided to drive around for about ten minutes. The temp gauge is still at cold. Now, the fan doesnt come on and it's been like that with the old thermostat. But before I replaced the old thermostat, the temp gauge would rise and fall like it was normal. So I am not sure what's going on. Please help.
Old Dec 8, 2004 | 08:06 PM
W0oT's Avatar
Banned
Default Re: Thermostat problem (pisetup)
hmm... make sure ur fan is plugged in... hook 12v to 1 lead to fan and ground other lead to test to make sure it's working. if so. check fuses... or run a contanuity test from one end of the circuit to the other. fusebox to fan ect...
thermoswitch?
Old Dec 8, 2004 | 08:09 PM
pisetup's Avatar
Where would the thermoswitch be located for a JDM D15B?
Old Dec 8, 2004 | 08:26 PM
W0oT's Avatar
Banned
Default Re: (pisetup)
if it has one it's a 1 wire threaded plug that is threaded into the block under the dizzy on my b16. and i think there's another but i can't remember.. i know one is for the fan and one is for the gauge.
Old Dec 8, 2004 | 09:21 PM
doublethink's Avatar
Default Re: (Majin Vegita)
anyone know if the lower radiator hose should be cold? if its cold what does that mean?
Old Dec 9, 2004 | 03:51 AM
pisetup's Avatar
I think it's clogged somewhere. I'm going to try and drain the radiator to see if that'll fix my problem.
KC Integra
Jun 3, 2013 04:10 PM
$amGD3
Jul 26, 2010 09:24 AM
aasaa666
May 31, 2010 07:15 AM
hayn420
Mar 24, 2009 08:06 AM
redacura
Acura TL, RL & ZDX
Feb 22, 2007 06:34 PM
