Z6 block + Y8 head = ? headstuds?
Old Dec 8, 2004 | 06:25 PM
MooreBoost's Avatar
Default Z6 block + Y8 head = ? headstuds?
I have a Z6 block, and a Y8 head, what headstuds do I use?
Old Dec 8, 2004 | 06:33 PM
Machine1's Avatar
Default Re: Z6 block + Y8 head = ? headstuds? (tegunderpressure)
I'm interested to know also. Please only reply if you have already done the combo.
Old Dec 8, 2004 | 06:37 PM
AgentJam's Avatar
Default Re: Z6 block + Y8 head = ? headstuds? (Machine1)
i have...one minute let me dig up my previous thread...
Old Dec 8, 2004 | 06:40 PM
AgentJam's Avatar
Default Re: Z6 block + Y8 head = ? headstuds? (AgentJam)
http://www.d-series.org/forums...=9752
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">i have...one minute let me dig up my previous thread...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">Ok ladies...this is the deal
IF YOU WANT TO RUN ARP STUDS ON Z6 BLOCK/Y8 HEAD YOU NEED THE FOLLOWING:
1) Z6 STUD KIT
2) PN# AM6.100-1LB DIRECT FROM ARP (1 piece)*
* This piece will replace the Z6 stud in the corner where the VTEC solenoid is located on the Y8 head. You need this part and neither a Z6 stud or Y8 stud will work. PN# AM6.100-1LB has same pinch/diameter as Z6/Y8 except it is between the two in terms of its length...perfectly fitting the application.
Vince</TD></TR></TABLE>
There ya go! hehe my misery is now to your benefit
Vince
Old Dec 8, 2004 | 06:44 PM
MooreBoost's Avatar
Wow, what a pain in the ***.
Thanks though.
Edit- I may as well just find a z6 head...
Old Dec 8, 2004 | 06:45 PM
Machine1's Avatar
I figured one of the studs didn't match up right. Because I was putting one together and neither the Y8 or Z6 studs worked.
AgentJam your are king for having that info
Modified by Machine1 at 9:59 PM 12/8/2004
Old Dec 8, 2004 | 06:48 PM
AgentJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Wow, what a pain in the ***.
Thanks though.
Edit- I may as well just find a z6 head... </TD></TR></TABLE>
No way man...lol why is it so hard?
You just have to get a z6 kit...then order PN# AM6.100-1LB from ARP (i had it overnighted for like $20 shipped - i was in the middle of my build).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Machine1 &raquo;</TD></TR><TR><TD CLASS="quote">I figured one of the studs didn't match up right. Because I was putting one together and neither the Y8 or Z6 studs worked.
AgentJam your are king for having that info </TD></TR></TABLE>
LOL no prob man...you should have seen me. I was in the middle of a build and needed the car running in like 3 days. I had bought both Y8 and Z6 ARP stud kits and with all those studs couldn't get it all together because of that one location.
Vince
Old Dec 8, 2004 | 06:50 PM
AgentJam's Avatar
Thanks though.
Ohhh you want to use stock...well...you "could" try and use all the y8 studs.
BUT, that one location near vtec solenoid...the stud will not bite into block anymore than 3/4" and i'm afraid if you tightened that you'd risk cracking the block. Possible...but i wasn't risking it.
Vince
VtecKiDD
Sep 21, 2006 02:23 PM
turbo sol
Mar 2, 2006 11:57 AM
Maxpower350
Feb 25, 2006 11:57 AM
Cruiser G
Feb 6, 2004 11:26 AM
JDMlyfestyle
Jun 16, 2003 06:54 AM
