4 wires on universal o2 sensor....where do they go?
Old Dec 8, 2004 | 05:55 PM
spidermancivic's Avatar
Default 4 wires on universal o2 sensor....where do they go?
my denso universal o2 sensor part # 234-4209 just came in. 2 blacks, 1 blue, 1 white. does it matter where the 2 blacks (positive and ground) go. if it does matter, how do you know which is which?
Also, Also there is a little packet of brown liquidy stuff that came with it, along with heat shrink tubing, and metal tube connections. what is that brown stuff?
cant i just solder them on?
Old Dec 8, 2004 | 05:58 PM
Brodie Bruce's Avatar
Default Re: 4 wires on universal o2 sensor....where do they go? (spidermancivic)
I'm pretty sure if it came with brown stuff that it is anti-sieze. Put it on the threads of the sensor before you torque it down into the bung. Don't get any on the sensor part though. Yeah, just solder the wires together. Find out which needs positive and which needs ground though. I am not sure if it matters.
Old Dec 8, 2004 | 06:10 PM
civictildeath's Avatar
Default Re: 4 wires on universal o2 sensor....where do they go? (xavenged7x)
ya i am almost positive it doesnt matter but when i did mine, where the blue wire goes into the sensor i put that up and did the same with the wire it hooked to and line matched the rest as they were.
cnydc2
Aug 6, 2009 08:32 AM
neu-b
19
Jun 30, 2009 06:03 PM
92B20VTEC
Apr 24, 2009 12:59 PM
conguero
Nov 18, 2004 06:36 PM
Flexmyrex
Apr 7, 2003 06:52 PM
