Holy shit! Can this be fixed?
Old Dec 8, 2004 | 05:11 PM
1point7db2's Avatar
Default Holy ****! Can this be fixed?
I was riding around my neighborhood today with no hood on when I noticed something really odd...when I accelerated the right fron side of my car would lift like 3 inches, and when I depressed the brake it went 3 inches in the opposite direction. closer inspection revealed a crack in my frame in front of my passenger mount. I did not do this swap (H22A in a CRX) nor do I know who did, but it looks like they did a crappy job when they cut out the frame. I dont care I got the car for dirt cheap, I just need to know if i should fix it or pull the motor and trash the body. thanks.
Old Dec 8, 2004 | 05:13 PM
EL Vap133's Avatar
Default Re: Holy ****! Can this be fixed? (h22rexguy)
This guy here had the same problem or similar and he had it fixed. Let me see if I can find the thread.
Old Dec 8, 2004 | 05:19 PM
88_DX's Avatar
How bad is that rust
Old Dec 8, 2004 | 05:26 PM
1point7db2's Avatar
Default Re: Holy ****! Can this be fixed? (88_DX)
The rust isn't bad at all this just happened I think.
Old Dec 8, 2004 | 05:32 PM
Dragline's Avatar
You can fix that you will to lay steel plate over the crack and weld it.
Old Dec 8, 2004 | 05:38 PM
1point7db2's Avatar
Default Re: Holy ****! Can this be fixed? (dragline)
Thats what I was thinking when I saw it I just dont know much about fab work or welding and didn't know for sure if it would work.
Old Dec 8, 2004 | 05:47 PM
Dragline's Avatar
It will work ,its before the strut tower so it should be a easy fix after you get ever thing squared and straighted back up.
Old Dec 8, 2004 | 05:51 PM
1point7db2's Avatar
Yeah I can definitely tell that somethings not lined up, the left headlight is like sitting crooked and the bumper doesnt line up on that side. Thanks alot for the advice. I was thinking about getting rid of the car.
Old Dec 8, 2004 | 06:01 PM
Dragline's Avatar
How much do you want for it?
Old Dec 8, 2004 | 06:06 PM
1point7db2's Avatar
make me an offer. a reasonable offer.
Old Dec 8, 2004 | 06:10 PM
Dragline's Avatar
Does it run fine besides the other problems?
Old Dec 8, 2004 | 06:20 PM
1point7db2's Avatar
It needs a few minor things- it has a fluctuating idle between 1500-2000 rpm. not at idle but when you rev it up to 1500 it fluctuates. The other day when I was unplugging the ecu pulled a wire loose and havent re-soldered it yet. so v-tec stopped working. but these are simple problems. the car has a six-puck unsprung with a fidanza 8lb. flywheel the head is fresh, less than 500 miles, it has a 30,000 mile block. no grinds in tranny. very smooth. the body is almost perfect besides the to fenders have a few dents. I ran the car 3 times - a 13.7 then 13.9 then 13.5 this is on street tires with alot of wheelspin, I wasn't used to the car, only had it a day before I ran it.
Old Dec 8, 2004 | 07:18 PM
Jared's Avatar
it could be fixed, put it on a frame machine, get that thing squared back up and even and weld that sucker up with some reinforcement.
Old Dec 8, 2004 | 08:15 PM
eL`mIEkLo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">You can fix that you will to lay steel plate over the crack and weld it.</TD></TR></TABLE>
yup yup
Old Dec 9, 2004 | 08:01 AM
HamiltonRex's Avatar
Default Re: Holy ****! Can this be fixed? (eL`mIEkLo)
make the the car is STRAIGHT. Use measuring points from the manual for the front end.
Once its straight, Weld both sides. Then lay a 1/8" plate over it and weld all the way around the plate, do this on both sides. Use a large mig or an arc welder. On the mig run 0.035" wire and do a vertical up mulit-pass. If your using an arc welder i recommend. 7018 run it around 135-140 and use 3/8" rods.
When i say both sides, i mean both sides of the crank, both sides of the car is obvious.
Goodluck.
If you want to sell PM me.
justseeingifitistaken
25
Dec 9, 2007 07:31 AM
kai-chun
14
Nov 1, 2006 06:57 PM
user 98292739
31
Apr 4, 2005 10:04 PM
BigHeadKid
Welding / Fabrication
13
Jan 8, 2005 06:43 PM
94whtgsr
74
Mar 30, 2004 12:42 PM
