clutch probem
Old Dec 8, 2004 | 05:06 PM
johknee's Avatar
Default clutch probem
I have a 92 civic ex, 1.5 liter. My clutch pedal is starting to stick, it takes a second to lift up, and at the same time i feel movement in the brake pedal. Any ideas?
Old Dec 8, 2004 | 05:12 PM
EL Vap133's Avatar
Default Re: clutch probem (johknee)
Does the car lag when you take off?
Old Dec 8, 2004 | 05:36 PM
civiccpedx's Avatar
Default Re: clutch probem (EL Vap133)
well first off that has the 1.6 liter. but i would say check the clutch fluid, and/or bleed the line.
Old Dec 8, 2004 | 05:58 PM
SOHCD16y8's Avatar
Default Re: clutch probem (civiccpedx)
if that doesnt fix it check the pedal linkage for interference and look to see if the fork on the slave cylinder moves freely
Old Dec 8, 2004 | 06:06 PM
johknee's Avatar
Default Re: clutch probem (SOHCD16y8)
thx bud
Old Dec 8, 2004 | 06:24 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Yeah if the pedal assembly isn't loose and fluids are fine. I would check your clutch master cylinder. Take a flash light and look under your dash. If there is clutch fluid seeping out of the back of the master cylinder I would suggest replacing it. To me it doesn't sound like it is the actual clutch. Bleed the clutch system too before you go replacing ****.
jlowellintegra
Nov 27, 2010 08:15 PM
Gomdohree
Apr 24, 2008 06:20 AM
Lb1atx
Sep 7, 2007 05:16 AM
The Droogan Leader
Oct 6, 2006 12:05 PM
Dsee2
Oct 23, 2005 10:10 PM
