Installing a Fuel pump kill switch in a CRX....and now it wont start.
Old Dec 8, 2004 | 03:10 PM
B16CRXT's Avatar
Default Installing a Fuel pump kill switch in a CRX....and now it wont start.
This is in a 91 CRX Si....
I checked the harness for the power wire. Found it then proceeded to solder a wire into the black wire that did not have power (I have 4 wires: yellow/black stripe, yellow, black/silver stripe, and black/silver dots). I cranked teh car on, flipped the switch and the car continued to run. Flipped it the otehr way, it still ran. Spliced into the black/silver dots wire and went through the same procedure. It did not cut the car off.
I got fed up with soldering and unsoldering wires (I'm a lazy dumbass..I know), so I decided to jump a wire from teh switch to the connectors for the remaining yellow wire. It sparked and the car cut off and hasnt started back up since. When you turn the key "on" the fuel pump does not pressurize the system.
Whast teh problem? Fuel pump blown? Main relay fried? I tried replaceing the small relay that is just behind the Hood release to no avail.
Also, could teh reason it shorted out be due to me jumping the wire while it was running? Should I solder the wires together at all times to avoid that (in other words: if I solder to that wire, once I fix this problem, will it still short something out)??
TIA!!!
Old Dec 8, 2004 | 03:20 PM
93civicEX's Avatar
Default Re: Installing a Fuel pump kill switch in a CRX....and now it wont start. (B16CRXT)
I'm pretty sure there is a fuse for the fuel pump, I bet you blew that. Check it
Old Dec 8, 2004 | 03:25 PM
b00sted93Hatch's Avatar
Default Re: Installing a Fuel pump kill switch in a CRX....and now it wont start. (93civicEX)
Yea what he said. It probably a fuse. Check under the hood for the ecu fuse. BTW anytime you work on your car, its a good thing to disconnect the battery.
Old Dec 8, 2004 | 03:47 PM
B16CRXT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicEX &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure there is a fuse for the fuel pump, I bet you blew that. Check it </TD></TR></TABLE>
Fuses were the first thing I checked. Forgot to mention that. There is no fuel pum pfuse that I could find. Unless tehre is another fuse box somewhere that I dont know about ( i checked under driver dash and under hood at teh main fuses).
When I turn the key on, everything turns on except the pump. I can turn teh motor over but it wont start. (no fuel)
Old Dec 8, 2004 | 04:07 PM
JDMotive's Avatar
Maybe the relay shorted out.Its under the dash,drivers side above the hood release.
Old Dec 8, 2004 | 05:46 PM
B16CRXT's Avatar
Default Re: Installing a Fuel pump kill switch in a CRX....and now it wont start. (JDMotive)
yea teh main relay. It is getting power....
Old Dec 9, 2004 | 08:52 AM
JDMotive's Avatar
Have you checked the pump to see if its still working?Pull it off and check it with a cordless drill battery or something along those lines.
Old Dec 9, 2004 | 07:29 PM
B16CRXT's Avatar
well...it tured out that after I installed thenew fuel pump today and new relay.....it was a ******* fuse.
I overlooked it somehow the first 2 tiems I looked for blown fuses. It was labeled under "ALTERNATOR SOLENOID VALVE" wtf?
Old Dec 9, 2004 | 10:47 PM
blackdelslo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and now it wont start.</TD></TR></TABLE>
Flip the kill switch
Old Dec 10, 2004 | 11:32 AM
tgreaves's Avatar
Default Re: Installing a Fuel pump kill switch in a CRX....and now it wont start. (delLudeVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Flip the kill switch </TD></TR></TABLE>
You beat me to it..
Old Dec 10, 2004 | 03:40 PM
dumpeDc2's Avatar
I'm a Jackass
haha
almostboostedgsr
Apr 8, 2009 10:29 PM
ludecrasy87
Nov 24, 2006 10:47 AM
DarkDragon
Jun 12, 2005 12:03 PM
B16CRXT
18
Dec 12, 2004 07:45 PM
smokinvtecCRX18
Jun 15, 2003 01:31 PM
