Are 310 injectors too small for this 2.0L, ported head, 12.5+ compression??
Old Dec 8, 2004 | 12:51 PM
JerseySiPOS's Avatar
Default Are 310 injectors too small for this 2.0L, ported head, 12.5+ compression??
I got a big time deal on a resleeve GSR block and ported head job and gonna go with 12.5+ compression.
Ive been running Toda b cams in my b16 and time to get this thing moving.
Here is the setup im going with. The cams and boltons are already on the b16.
Ported head with 5 angle
Toda b cams with Toda valvetrain and cam gears
Bored 70-65mm ITR TB
AEBS manifold
KOS 4-1 header with 2.5" collector, 2.5" exhaust
Regulator
255 pump
CM stage 3 clutch
8 pound fly
RC 310 injectors
84 or 85mm on the sleeved GSR block
Endyne Rollerwave pistons
eagle rods
new bearings, seals, gaskets, pump
either GSR or LS crank i need
I already have a p28 with custom toda program and vafc
Are the RC 310 injectors from my existing setup too small for this setup?
Im hoping to crack 220+ from this setup, but dont wanna high expectations.
thanks for any advice
Old Dec 8, 2004 | 01:11 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Are 310 injectors too small for this 2.0L, ported head, 12.5+ compression?? (JerseySiPOS)
every motor is different, you will know about the injector size when you dyno the car and check the air/fuel ratios v/s the fuel press, just an opinion but if you are above 55psi then you need to step up to 370cc injectors... just my .02
Old Dec 8, 2004 | 01:18 PM
Default Re: Are 310 injectors too small for this 2.0L, ported head, 12.5+ compression?? (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">every motor is different, you will know about the injector size when you dyno the car and check the air/fuel ratios v/s the fuel press, just an opinion but if you are above 55psi then you need to step up to 370cc injectors... just my .02</TD></TR></TABLE>
ok, thats perfect because, i do have a wideband in the car, a custom program (thanks to CHEETAH ) and vafc. my plan would be to break the motor in before going to the dyno, and ill get a perfect idea of where ill be at with the 310 injectors.
so yeah, i guess i coulda answered my question. i am gonna start around 42 psi and try to keep the vafc at 0%.
Im might go hondata when comes time for the dyno.
Old Dec 8, 2004 | 01:53 PM
DYNO-PRO
Combustion Contraption
Nov 17, 2004 02:20 PM
jeremy.
12
Sep 27, 2003 08:07 PM
AussieK24
May 13, 2003 11:11 AM
AZTodaSi
Aug 22, 2002 09:09 PM
