To balance or not to balance that is the question!!!!
Old Dec 8, 2004 | 09:20 AM
rextec's Avatar
Default To balance or not to balance that is the question!!!!
i just built my first engine and i didnt get my crank balanced, now i was wondering will i be ok? the setup is as follows d16z6, cp 75.5 9:1 pistons, micro polised crank, acl bearings, eagle rods. has anyone built a motor without balancing the crank and had luck with it? i have an sc34 and plan on running around 16psi of boost (350ish hp). i really dont feel like taking the bottom end apart again.....
Old Dec 8, 2004 | 02:22 PM
PrettyLude's Avatar
get it balanced
Old Dec 8, 2004 | 03:39 PM
Dragline's Avatar
Default Re: To balance or not to balance that is the question!!!! (rextec)
Aways balance,never cut corners
Old Dec 8, 2004 | 03:57 PM
servion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote"> i just built my first engine and i didnt get my crank balanced, now i was wondering will i be ok? the setup is as follows d16z6, cp 75.5 9:1 pistons, micro polised crank, acl bearings, eagle rods. has anyone built a motor without balancing the crank and had luck with it? i have an sc34 and plan on running around 16psi of boost (350ish hp). i really dont feel like taking the bottom end apart again.....</TD></TR></TABLE>
Honda cranks are very well balanced from the factory. I did not (nor have I ever) had a honda crank balanced. No problems (current setup makes over 500whp on 100% stock crank)
The only concern I have for your situation is, how much was done with the micropolish job? I.E., did the crank polishing job do enough to throw the crank off balance? Probably not...
Old Dec 8, 2004 | 04:15 PM
Dragline's Avatar
Do it right and get it balanced,just like he said above his concern is, is it still balanced.
Old Dec 8, 2004 | 04:56 PM
rextec's Avatar
Default Re: To balance or not to balance that is the question!!!! (servion)
it was just a very light cleanup pass, so i dont think it threw it off at all. i did a little reasearch and found i really dont need to balance it because my rods and pistons come pre balanced, and i think the factory can handle balancing a crank .
thanks for putting my mind at ease
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">
The only concern I have for your situation is, how much was done with the micropolish job? I.E., did the crank polishing job do enough to throw the crank off balance? Probably not...</TD></TR></TABLE>
spun Vtec
Jan 29, 2007 01:49 PM
cherryhatch00
Jan 15, 2007 02:57 PM
carboy_honda
19
Jan 6, 2007 04:59 PM
hondaaccord94
Feb 16, 2006 06:23 PM
caspers_hatch
Aug 12, 2005 09:35 PM
