Ignition Switch Swap
Old Dec 8, 2004 | 09:17 AM
One Bad GeeSeeR's Avatar
Default Ignition Switch Swap
okay heres the deal. i want to know if an integra ignition switch with the immoblizer can be swapped in a 97 civic hatch back. the reason of doing this, i will be getting a 00 itr swap and i have use a us spec ecu. which has the immoblizer i dont want to removed the chip that governs the immoblizer because it will cause a cel light which i wont pass the BAR.
number 1 is what i am looking at. its the whole key and lock assembly.
Old Dec 8, 2004 | 09:51 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Ignition Switch Swap (One Bad GeeSeeR)
Im sure its possible.. but thats going to take a lot of wiring as far as i know.
Old Dec 8, 2004 | 02:10 PM
Default Re: Ignition Switch Swap (JDM_Ej)
wiring doesnt really scare me . can anyone confirm this?
Carlo
Old Dec 9, 2004 | 12:32 AM
Stripped Honda's Avatar
99-0104
i just installed my ignition in my 01 gsr and it isnt that much bigger then the no immobolizer model ... only thing would be the wiring issues but you say its no problem for you
if you need a ignition i have a complete lock set for sale ... with immobolizer ignition
White Lightnin
Oct 17, 2023 08:10 PM
Toomanylemons
Mar 5, 2017 11:27 AM
burninrock24
Jun 26, 2012 02:34 PM
SoHc Ej1
Sep 26, 2008 06:19 AM
Wayne_Curr
Nov 15, 2006 12:51 PM
