TEST ONLY smog check with Vafc and cam gear
From: South Bay, Torrance/Carson, CA, United States
I'm about to get my smog check done. A friend of mine knows a test only guy that will let the visuals pass as long as I pass the emissions part. So I was wondering: what are the best settings for a Vafc and cam gear as far as getting the cleanest emmisions? Thanx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">well what have you done to your car?
Its a jdm d15b, i,h,e, cam gear (tuned), vafc (tuned), hi flo cat, fuel pressure regulator (tuned), and pulleys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">If everything is tuned to 14.7 you should pass.
If not write down all your settings and go back to stock then go back to tune when your done. </TD></TR></TABLE>
I'm sorry but which settings should go to 14.7???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvjasmine »</TD></TR><TR><TD CLASS="quote">
I'm sorry but which settings should go to 14.7???</TD></TR></TABLE>
you a/f ratio should be tuned to 14.7 (which is pretty hard to do w/o a wideband). I just say zero EVERYthing out (cam gear, vafc, fuelpressure). there's no reason that a stock d15b with i/h/e shouldnt pass
blackitrspec
Apr 3, 2002 08:37 PM
