Early XMas Gift (My condolences to 56k)
Old Dec 7, 2004 | 11:04 PM
ServiceAdvisor's Avatar
Default Early XMas Gift (My condolences to 56k)
This is a D16Y8 Head that had a mild PNP. It was just sitting in a friends garage and he let me have it providing I take it home ASAP so he'd have more room for his 'Poor mans Type R' project. From another friend I aquired a D15B7 Block from a 94 DX HB. I would just like more info on how this swap goes into my ED9 Chassis. I've gathered quite a bit of info from here http://www.angelfire.com-ca-DrOhm-hybrid.html TIA for any [HELPFUL] replies, - Darrell
http://www.we-todd-did-racing....D.jpg
- Darrell
Modified by DOHCZCCRXSi at 11:37 AM 12/8/2004
Old Dec 7, 2004 | 11:18 PM
Magick211's Avatar
Default Re: Early XMas Gift (DOHCZCCRXSi)
As far as putting the motor in its fairly easy. but i take it you havent done much motor work so i wouldnt recoment you assembling the motor yourself.
Old Dec 7, 2004 | 11:29 PM
Actually, I'm quite good with a wrench, I just don't know off hand what motors/blocks fit which bodies, and what preparations are necessary in transplanting this motor. I always thought I had to get a large amount of parts for this swap. I actually don't even know where to begin the search . The reason I have a DOHCZC is cause it was a bolt-on affair. I thought I'd need mounts/hydro tranny conversion/axles ect for a Single Cam VTEC swap. Maybe I could be pointed in the right direction? - Darrell
Old Dec 8, 2004 | 12:37 AM
Ok, from what I gather, the head is a d16Y8 from a 96+ Civic EX (EJ8) and the block is a D15B7 from A 92-95 CIVIC DX/LX. I can use my stock 91 CRX Si harness/axels/hubs/tranny/mounts/and ecu I just have to get a FPR, RPM activation switch <- Endyn reprogrammed PM6 ECU. I can use a D16a6 dizzy from my old stock motor, but it might fit a bit awkward so modifying it will be necessary. And I should use the D16A6 T-Belt since its 104 teeth not 103 like the VX? I should use the 92-95 Alternator since its a 4 rib not 3 like the 89-91. If anyone has any objections or opinions/ideas/[BOLD]INFORMATION[/BOLD] plz share, thanks. - Darrell
Old Dec 8, 2004 | 01:28 AM
Redline130's Avatar
Default Re: (DOHCZCCRXSi)
I don't know if I'm missing something here, but why are you doing a mini-me when you have a ZC already in your car?
Old Dec 8, 2004 | 01:39 AM
sheissrx's Avatar
Default Re: (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if I'm missing something here, but why are you doing a mini-me when you have a ZC already in your car?</TD></TR></TABLE>
Old Dec 8, 2004 | 02:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if I'm missing something here, but why are you doing a mini-me when you have a ZC already in your car?</TD></TR></TABLE>
I guess you know very little of ZCs. Aftermarket for a ZC is next to nothing. My funds will not allow me to do the modifications to this engine which would net me the results I want. Also, forced induction is not in my future, very much limiting the possibilities of my DOHCZC. Also, I'd like to pursue another motor, considering this one I paid $0 dollars for. And whose to say I'm not keeping the DOHCZC for lets say.. My gfs ride? Again, I'm just asking for information, not questions as to why I am doing what I am. But thank you for the interests in my post. - Darrell
Old Dec 8, 2004 | 06:51 AM
DieMaster's Avatar
Needs to be About 20% Cooler
i apoligize for my noob-isum but the cam in the first pic is a VTEC cam right?
Old Dec 8, 2004 | 08:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i apoligize for my noob-isum but the cam in the first pic is a VTEC cam right?</TD></TR></TABLE>
Yes, its a stock D16Y8 cam. - Darrell
Old Dec 8, 2004 | 10:41 AM
DJ_SaNdOz's Avatar
I'd keep the ZC if I were you.....I don't know why people say they can't find parts for them. What parts do you want that you can't find? I'd personally set the new block/head aside for later, just in case you get an OBD1 car, or kill the ZC.
Old Dec 8, 2004 | 10:43 AM
HumanResource's Avatar
Doesn't look like the D16Y8 from the combustion chambers, but it might be the fotos?
What Serial CODE is on it?
should read "P2J"
Old Dec 8, 2004 | 10:53 AM
89civicdx's Avatar
Default Re: Early XMas Gift (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't look like the D16Y8 from the combustion chambers, "</TD></TR></TABLE>
Old Dec 8, 2004 | 12:12 PM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't look like the D16Y8 from the combustion chambers, but it might be the fotos?
should read "P2J"
Thats because its not. No quench pads = Not a Y8.
Kinda looks like a Z6 to me. Your compression is going to be lower than what you think it is.
Old Dec 8, 2004 | 12:14 PM
Default Re: (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">I'd keep the ZC if I were you.....I don't know why people say they can't find parts for them. What parts do you want that you can't find? I'd personally set the new block/head aside for later, just in case you get an OBD1 car, or kill the ZC.</TD></TR></TABLE>
I concure. You just havn't been looking hard enough.
Old Dec 8, 2004 | 02:49 PM
DJ_SaNdOz's Avatar
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">
I had a ZC, and quickly realized that the "no parts" thing is just a myth made up by lazy people. I miss my ZC Si, it seemed way peppier than my D15B VTEC EG.
Old Dec 8, 2004 | 02:51 PM
I had a ZC, and quickly realized that the "no parts" thing is just a myth made up by lazy people. I miss my ZC Si, it seemed way peppier than my D15B VTEC EG.</TD></TR></TABLE>
That would be attributed to the 90mm stroke and DOHC head...
I loved my ZC, but I'm gonna go Y8/A6 Hybrid with my Beater hatch.
Old Dec 8, 2004 | 04:17 PM
My ZC is going under the knife and will soon find track only conditions. But I need another motor to put in and I had come across a deal, free block/head so why not? Your right, not a Y8, head says P08-4 and it has a VTEC solenoid. Find me a complete valvetrain for my ZC that isn't going to be 2-3x's the price of the valvetrain for a Single Cam VTEC and you will get a big from me. But again, I guess I can't emphasize enough, I DO NOT WANT QUESTIONS AS TO MY MOTIVES, merely the information as to how I can combine the above pictured head to a D15B7 block. TY for the replies, keep 'em coming. - Darrell
Old Dec 8, 2004 | 05:03 PM
DJ_SaNdOz's Avatar
https://honda-tech.com/zerothread?id=554053
Old Dec 8, 2004 | 05:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">My ZC is going under the knife and will soon find track only conditions. But I need another motor to put in and I had come across a deal, free block/head so why not? Your right, not a Y8, head says P08-4 and it has a VTEC solenoid. Find me a complete valvetrain for my ZC that isn't going to be 2-3x's the price of the valvetrain for a Single Cam VTEC and you will get a big from me. But again, I guess I can't emphasize enough, I DO NOT WANT QUESTIONS AS TO MY MOTIVES, merely the information as to how I can combine the above pictured head to a D15B7 block. TY for the replies, keep 'em coming. - Darrell</TD></TR></TABLE>
Take out the blocks oil squiter, and bolt it on.
Happy?
Old Dec 8, 2004 | 05:24 PM
EL Vap133's Avatar
silly d series guys....
Old Dec 8, 2004 | 06:34 PM
krazie1's Avatar
BANNED
Default Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">silly d series guys.... </TD></TR></TABLE>
Hater!!
Why not let the D series guys have the fun too, I know I know they can't come close to us B series guys but the same as Us B series guys can't touch the "K" series ballaz
Old Dec 8, 2004 | 06:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Take out the blocks oil squiter, and bolt it on.
Happy?</TD></TR></TABLE> Actually, yes, quite. TY for a short, simple, and DIRECT reply bryson . Even if was ment in an ill-tempered manner. DJ, thanks for the link . TY to all those who posted, be it helpful or not. - Darrell
BTW, I still &lt;3 my ZC and would take it with spun bearings and a blown HG before I'd step V DOWN V to a B16 x 10 million multiplied by the speed of time in MHZ.
Old Dec 8, 2004 | 07:09 PM
essex's Avatar
z6 head is better than a y8 so be happy
Old Dec 8, 2004 | 07:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">z6 head is better than a y8 so be happy </TD></TR></TABLE>
Maybe you could elaborate alittle more? - Darrell
Old Dec 8, 2004 | 07:26 PM
Default Re: (essex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by essex &raquo;</TD></TR><TR><TD CLASS="quote">z6 head is better than a y8 so be happy </TD></TR></TABLE>
Umm...no its not.
Y8 Flows better, has a better cam, has quench pads, nets a higher compression, and its newer.
And...how is the Z6 better?
