removal of radio, help please
Old Jan 2, 2002 | 10:35 AM
Bbasso's Avatar
Default removal of radio, help please
The dash panel around the radio in a ITR, how the f-ck do I get it off I tried taking out all of the screws and still nothing. I had taken out the center armrest removed the lower dash under the steering wheel and still i could not find the magic bolt, I know it has to have a hidden clip or two but what do I do?
even with all that removed it was still very secure and not much slack...
HELP
HELP
HELP
Old Jan 2, 2002 | 11:51 AM
Spade's Avatar
Default Re: removal of radio, help please (Bbasso)
There is a screw if you look strait up underneath the center that goes into the radio supports......if that is removed then you are just pulling on attached cabling.....detach all cables/connectors from the dash unit.
Old Jan 2, 2002 | 02:12 PM
Bbasso's Avatar
ok maybe this would help u to help me, i took out the screws(one on each side) toward the front on the side then the three in the ashtray(straight in) then i took out the center armrest two screws on each side and the two that hold down the center armrest and the shifter console. does the cf base plate around the shifter come out if so how? just pull? another... the little pocket under the radio, how is that held in. does the slide out cup holder stay in or does it have to be removed?
thanks for the help,Bbasso
Old Jan 2, 2002 | 05:39 PM
StinkyTofu's Avatar
Not sure what you're talking about, but i found this for you. Hope it helps, good luck!
http://www.team-integra.net/ti/elec/radio-remove01.asp
Old Jan 3, 2002 | 08:16 AM
Bbasso's Avatar
Default Re: removal of radio, help please (B-18C1)
thank you very much that helped all the way!!!
Old Jan 3, 2002 | 08:24 AM
StinkyTofu's Avatar
No prob man! So it does work? I think i'll try it myself now
Old Jan 3, 2002 | 08:28 AM
Type R's Avatar
did you install a new stereo or are you doing a mod to your stock one?
Old Jan 3, 2002 | 11:37 AM
Bbasso's Avatar
Default Re: removal of radio, help please (Type R)
I'm going in to the garage right now with the knowledge from that web site.
I have a system from my old car, pioneer P1R and many other goodies...
[Modified by Bbasso, 3:39 PM 1/3/2002]
Old Jan 3, 2002 | 01:26 PM
Bbasso's Avatar
****** Pucker, I hit a snag...
The stock radio is mounted by the back and mine is mounted bu the sides and the car has no brackets along the side, ANY IDEAS??? i could make a bracket but it would be flimsy or is that what i have to do? (May be a kit made for it ?)
Old Jan 3, 2002 | 04:42 PM
civicjunkie's Avatar
New User
go to any local stereo shops and ask for whats called a "metra kit"
it has all the peices and instructions u will need
Old Jan 3, 2002 | 05:48 PM
Bbasso's Avatar
I got it, MANY MANY thanks for the help!! soon i'll have pics for everyone (couple of days)
Its going alot easier with all the help and links to other websites...
phoenix1310
Apr 12, 2011 05:53 PM
85_305
Honda Civic (2001 - 2005)
Aug 26, 2009 09:44 AM
DustinFinn
Jan 21, 2008 06:30 PM
96tegls
Dec 29, 2005 04:09 PM
